DAC listening test files - updated with new filters files
Both of the test filters (and the positive control) cut off at 20khz, some more sharply than others.
Would it be interesting to do 18,16, 14, 12, 10 or some combination of that?
I would vote for it. But again, the file set should be limited in number of files, if we want to get any meaningful feedback.
Reactions: j_j
I would prefer lower ripple examples down to the 0.1 dB we saw in that Topping DAC (D10s?). Since we will never encounter sharp 12 or 16 cut-offs in real DAC filters, this will just end up being an age discriminator.
Seeing @Thomas_A pass the test at 20 kHz, I would also be very interested in him repeating that with a different headphone and/or DAC+amp. And, of course, getting more people to participate. Maybe even more possible test files isn't the most critical thing right now.
I would say there is a point of 14-16-18-20 using the same filter. It gives you training and it shows limits in another way. Logically it should show up in the statistics. I do not know the difference with these new files vs the older one where I got 10/16, 10/16 and 14/16 in one take. Ripple present/absent?
Regarding other equipment, I have what I have…I may borrow some other headphones.
Since the audibility of ripple is incontrovertable (by the way, the filter that is detectable due to ripple is extremely similar (as in I don't have their filter weights but I mimic their response within a very, very small error) to an SRC filter box we had a while ago) any further tests will be with minimal ( .01dB or something like that) ripple. The ripple in the other tests is minescule. 0.1dB is way, way bigger than anything I'd include coming forward. Remember a "sharp cutoff" does not require more ripple.
Does that affect the phase linearity below 20k?
All of the filters are constant delay until the -120dB cutoff, and then flip between constant delay and inverted constant delay at every zero. In other words, you won't ever hear anything at that point in any case.
I can also use non-constant delay. For some of the shorter filters, I can also make a minimum phase version of the constant delay filter, maybe. (It's tricky, it depends on LOTS of word length when calculating roots of polynomials)
I am really interested in this. Do you have suggested further reading? It does seem to be what @pma was hearing. But what levels of ripple are audible? As well as the frequency "period" of the ripple? Is it detected by hearing the associated echoes, or poor flatness of frequency response? It seems fairly unexplored, but maybe there is more out there than I am finding searching for info on this?
The problem is that the space of possibilities is gigantic, enormous, and really, really hard to search efficiently, way way too many variables. "How much ripple" is one question, and 'how much ripple in what part of the spectrum" another, and yet another "is a constant delay filter with ripple better or worse than a minimum phase filter with the same amount of ripple". That's just for FIR filters. Then we can get to Elliptical vs. Cheby 1 vs. .... The space is humongous.
FYI the two "low ripple" filters have ripple of about 1e-4 dB Yes, you read that right. I had to blow up the vertical axis by 10,000 to see it. It is, in both cases, slightly low ( -1e-4 db) at bass and the edge frequency, and peaks and dips periodically between +- 1e-4 dB (Note, I'm using e-4 to mean 10^-4)
There is a new set of test files prepared by @j_j that can be downloaded from:
Again there is an original file and 4files created using various filters. Your task is to test (ABX) the dchesorig1.wav file against any of the remaining 4 files, and post the result, if you are interested in participating.
I am posting an anonymous image with comparison of the filter amplitude responses (with respect to the original file) for you to have an idea what is tested. All filters are low-ripple filters. Have fun!
The question isn't if it is audible, but until what level it stays audible. I know that it's not a problem to design filters with minimal ripple, but we do have an example in the thread where the manufacturer failed to do so. Others do exist: ESS apodizing filters come to mind, which seem to be around +-0.075 dB. So I do see value in testing this, but it's debatable what levels and what ripples per octave we should choose. To establish a threshold, we would need to cover a realistic range in any case.
After doing a quick search, I couldn't find good literature covering the topic. But I may have used the wrong search terms. So if you do have some good papers on this topic, I would appreciate the links.
Yes, the D10s seems to use that ESS filter you mention (so in this thread), and has a fixed filter so you can't switch to another. AKM has DACs and SRC with passband ripple too. So there are many products that have this, including the Pro-ject Pre Box DS2 that I use for the DAC in my main system (although I upsample in Roon first).
Exactly, how much ripple AND WHAT KIND of ripple. I've also seen and heard bad filters that had audible ripple DUE TO RIPPLE. Apodizing filters are for another problem, the potential of pre-echo in a constant delay filter. In any constant-delay filter, there are two sets of zero pairs, one inside the unit circle, and one at the inverse (1 / root) outside the unit circle.
To "apodize" such filters, you can simply invert any particular complex pair to be inside or outside the unit circle. If you invert ALL of the zero pairs outside the unit circle (note, you can't invert zeros on the unit circle, but they are for the stop band anyhow, in which the phase flips at every unit circle pole pair. Which pairs you choose DO NOT MATTER A BIT TO THE FREQUENCY RESPONSE! Yes, you can make many many filters with different impulse responses and exactly (to numerical accuracy) have the exact same frequency response, but ONLY those with all zeros inside the unit circle have an inverse zero outside the unit circle have constant delay. Somewhere here is a demonstration of how this can work.
Interestingly, such filters are exactly symmetric about the center of the filter. If the filter has a zero at DC, they can also be antisymmetric, but that's very rare for audio.
A minimum phase filter (all zeros moved inside the unit circle) has the shortest group delay at any given frequency, BUT the delay changes with frequency. A maximum phase (all zeros outside)has the most delay, but again, not constant delay with frequency. A symmetric filter has the same delay at all frequencies not in the far stop band, and as a result has a phase response that is a line with the slope of the line exactly describing the time delay of the filter hence the term "linear phase".
Most FIR's are constant delay. They don't have to be.
Oh, also, ripples per octave is not a thing for most FIR filters, it's "ripples per frequency". IIR filters are per octave (with warping in digital domains), but not FIR filters in general. Equiripple filters in particular will have a number of ripples in the passband, and another number of ripples in the stop band. The transition band is UNDEFINED and can be optimized for minimum ripple.
In my humble opinion we might go as low (with Fc) as 12kHz, minimum phase and linear phase filters, and see if they would show up.
Not hard to do, if you want.
Yeah, please let me post my test file, I am curious if it would show up (against the original dchesorig1.wav):
BTW, this file can also be directly subtracted from the original, to check what is the difference.
It is a 11kHz sharp roll-off, low ripple, constant delay.
... and zoomed
It is a 11kHz sharp roll-off, low ripple.
Code:
foo_abx 2.1 report
foobar2000 v2.0
2026-09-27 09:18:11
File A: dchesorig1.wav
SHA1: 9578d6c3b0a59c80ea046a0ecf3fa6688a3e2aff
File B: psxbvwg.wav
SHA1: 7cb3b49b80264fc61c0eb8eb4edf537a75765860
Output:
ASIO : Topping USB Audio Device
Crossfading: NO
09:18:11 : Test started.
09:19:53 : 01/01
09:20:07 : 01/02
09:20:32 : 02/03
09:20:39 : 03/04
09:20:49 : 04/05
09:20:57 : 05/06
09:21:04 : 06/07
09:21:29 : 07/08
09:21:56 : 08/09
09:22:12 : 09/10
09:22:22 : 10/11
09:22:29 : 10/12
09:22:29 : Test finished.
Total: 10/12
p-value: 0.0193 (1.93%)
 -- signature --
c09c9c6365d39cac7473b36f6a3d98e4a20e121a
