foo_abx 2.2.3 report
foobar2000 v2.25.7
0126-08-26 18:06:35
File A: DAC1.wav
SHA1: 5326127cd74c39e30bfcb9af3a3d001fc99d4022
File B: DAC2.wav
SHA1: bd5db7393f6be9c4a0c4df088e1af149625ed47d
Output:
Core Audio : DX5 [exclusive], 24-bit
Crossfading: NO
18:06:35 : Test started.
18:07:42 : Test restarted.
18:07:42 : 01/01
18:07:58 : Test restarted.
18:07:58 : 02/02
18:08:22 : Test restarted.
18:08:22 : 03/03
18:08:34 : Test restarted.
18:08:34 : 04/04
18:08:43 : Test restarted.
18:08:43 : 05/05
18:08:51 : Test restarted.
18:08:51 : 05/06
18:09:01 : Test restarted.
18:09:01 : 06/07
18:09:09 : Test restarted.
18:09:09 : 07/08
18:09:17 : Test restarted.
18:09:17 : 08/09
18:09:29 : Test restarted.
18:09:29 : 09/10
18:09:38 : Test restarted.
18:09:38 : 10/11
18:09:51 : Test restarted.
18:09:51 : 11/12
18:09:51 : Test finished.
Total: 11/12
p-value: 0.0032 (0.32%)
-- signature --
f169aac460cfe135235a35ae4272086c2cfc78f8
I checked that time stamp again and without investing hours into it, there certainly isn't any immediately audible difference to me. However, I see in your log that you're listening to it via the DX5, which is also one of the contestants. Can you distinguish them using any other DAC (excluding the DX5 and D10s)?Test #2 Topping DX5 x Topping D10s new result 11/12 (I new I did it few years ago as well). 12 trials is about maximum for me to keep concentrated.
I have to add that for normal listening is the difference (crash cymbal strike about the middle of the music sample) unimportant. The difference in fast transients, also seen in the Deltawave delta file, is IMO completely due to different filters transfer function.
Well - I promise I will try to repeat the 11/12 result or get something < 0.05 (p) again. It is not trivial.I checked that time stamp again and without investing hours into it, there certainly isn't any immediately audible difference to me. However, I see in your log that you're listening to it via the DX5, which is also one of the contestants. Can you distinguish them using any other DAC (excluding the DX5 and D10s)?
IMO -80dB/H2 audibility has not been reported in the literature. I am aware of -60dB/H2 audibility on pure sine reported by Bob Stuart, in quite narrow area of SPL and base frequency near 1.5kHz.EDIT: I checked the 1 kHz test signals and it came as no surprise that -20 and -40 dB are very obvious, while -60 dB is quite difficult to detect already. I didn't try -80 dB and I wouldn't expect to hear it. In any case, I think my IEMs (ZSN Pro X) are extremely average and their main strength was being extremely cheap. So maybe a small upgrade to some low distortion ones is indicated.
It is the crash cymbal strike near 10-11s of the music sample.I cannot find anything to try to use to pass Test 2.
Congratulations. I think that will come to be seen as a significant result.Test #2 Topping DX5 x Topping D10s new result 11/12 (I new I did it few years ago as well). 12 trials is about maximum for me to keep concentrated.
It's difficult to accept that differences in noise and distortion between good modern DACs are audible. So SINAD @ 1kHz won't tell you.If the main difference between the recorded files (DACs) is in the filters,
I still can't hear a difference. Do you see anything in DeltaWave in that timeframe?It is the crash cymbal strike near 10-11s of the music sample.
Yes. This post. And the DAC to keep flat, no passband ripple response.I still can't hear a difference. Do you see anything in DeltaWave in that timeframe?
It seems like the clock drift is not corrected in the files. When I correct in DeltaWave, then the matching is much better than what you show in that post. The RMS is better than -80dB when clock drift is corrected. Clearly you are hearing something, but the matching of the recordings is very good so it is not surprising to me that I can't hear anything.Yes. This post. And the DAC to keep flat, no passband ripple response.
P.S.: results chart updated (post #1 and further). Green pass approved if there are more than one result with p<=0.05, by the rule of the test result confirmation. Yellow pass needs to get p<=0.05 twice or more.
It is not, intentionally. When you would listen to those DACs with an A/B switch, it would not correct the drift as well. The drift is not any high. ABX positive result counts, nothing else. Try that transient near 9.5s. Due to filters difference in transfer function (i.e. amplitude AND phase), the difference is audible. I have chosen that music sample just because of the transients and for the reason that between rock bands this one has IMO best recordings quality. The difference is barely, however audible. If you do not mask it by the filter function of the DAC used for the listening test. And go exclusive mode or ASIO, no windows default drivers. No on-board sound card. Use a good external DAC.It seems like the clock drift is not corrected in the files
I know it doesn't matter for ABX. I mistakenly thought that clock drift was causing a fifference in what we are seeing in DeltaWave. I still don't get why you would expect to hear what you show in that DW graph. At 10-11 seconds, the worst of the delta are brief spikes of about -60dB. I am not being skeptical about your hearing the difference, I am just wondering why you think the chart of the delta shows something.It is not, intentionally. When you would listen to those DACs with an A/B switch, it would not correct the drift as well. The drift is not any high. ABX positive result counts, nothing else.
edit: and I was doing the ABX trial at 9 to 12.5 seconds. Do you think my SRC ripple of +/- 0.01 dB is masking something? I could upsample in DW before doing ABX if that might help.
