For people having questions or want to understands statistics of ABX tests, i wrote an article more than 10 years ago on this very topic! https://www.audiosciencereview.com/forum/index.php?threads/statistics-of-abx-testing.170/
I'm not sure. If the effect is borderline significant, it will always come down to that one test right on the edge that decides on which side of the border you end up.I fully admit that I'm not a statistician
To me too, but I mean the opposite direction than the one discussed. Fewer number of trials means smaller statistic power, i.e. smaller probability of detecting the effect in case when the effect really exists. In other words, it is more prone to not detect the effect (e.g. when the effect is small - real but small), because you can't make any mistakes. One wrong result and you are out.
I think I was just on the wrong track there with my ideasI agree that you need fewer individual lucky guesses in 5 trials, but I feel that this is counteracted by the fact that you need to be lucky at each and every step. So double lucky, one could say
That doesn't make sense to me. The simulation simply sums the wins. If the chance of a win in a single run were higher, that would sum to higher number. There's nothing in the simulation to "cancel out" previous wins.
Yeah, probably.If I had to come up with a reason for that, I'd say 16 is high enough to be sensitive to detect small differences and low enough to not cause (overly big) fatigue in the tester. And not that p<5% from 16 trials is somehow better than one from 10 trials.
foo_abx 2.2.3 report
foobar2000 v2.25.7
0126-08-25 22:14:23
File A: DAC1.wav
SHA1: 5326127cd74c39e30bfcb9af3a3d001fc99d4022
File B: DAC2.wav
SHA1: bd5db7393f6be9c4a0c4df088e1af149625ed47d
Output:
Core Audio : D10s [exclusive], 16-bit
Crossfading: NO
22:14:23 : Test started.
22:14:53 : Test restarted.
22:14:53 : 01/01
22:15:17 : Test restarted.
22:15:17 : 02/02
22:15:29 : Test restarted.
22:15:29 : 02/03
22:15:41 : Test restarted.
22:15:41 : 03/04
22:15:51 : Test restarted.
22:15:51 : 03/05
22:16:00 : Test restarted.
22:16:00 : 04/06
22:16:17 : Test restarted.
22:16:17 : 05/07
22:16:28 : Test restarted.
22:16:28 : 05/08
22:16:37 : Test restarted.
22:16:37 : 06/09
22:16:49 : Test restarted.
22:16:49 : 07/10
22:17:11 : Test restarted.
22:17:11 : 07/11
22:17:26 : Test restarted.
22:17:26 : 08/12
22:17:26 : Test finished.
Total: 8/12
p-value: 0.1938 (19.38%)
-- signature --
00ae4a7513d558e52b137c495d1f8bec7acb7ac5
Talking about macos only.We need to find the way how to set foo abx to operate at 24 bit resolution with 24 bit files.
Yeah I don't think there is much chance I can get to a good p value. It feels very close to pure guessing with the slightest impression that I could be hearing some difference. And I think I am making up the idea I could be hearing something.@pjug Your last three tests combined would be 28/48 with p=15.6%The 5% threshold would be reached at 31 correct guesses.
I *think* that if you used foobar in exclusive mode, and chose a WASAPI (the default now in foobar) or ASIO device. it would bypass those Windows 'audio enhancements' if they were enabled.Oh crap. Last test audio enhancements were not turned off. I don't know if that matters or not. I should ask for help. @pma does this look OK for the 44.1/24 files and do you want me to redo the tests with these settings?
If you use "Your DAC's name [exclusive]" in foobar2000 none of those Windows settings should matter (except the "Exclusive mode" settings themselves, of course). At least for me, the DAC then switches to the sample rate of the track being played back.Oh crap. Last test audio enhancements were not turned off. I don't know if that matters or not. I should ask for help. @pma does this look OK for the 44.1/24 files and do you want me to redo the tests with these settings?
Only? I am 71edit: Better ears might help too! I am 62 yrs old.
