DAC for active speakers and headphone amp - Suggestions?
jacobtc
So I am looking for a DAC that can support a couple of active speakers and my existing LovelyCube headphone amp.
I am getting a couple of B&O BeoLab 3 speakers that I want to use with my PC, and I want a new DAC for two reasons.
1. Sound quality
2. I do not trust Windows volume management. These speakers should be kept at a very low volume, and in my experience, Windows just randomly chooses that an output should suddenly be at max volume.
I would love to have a setup that lets me have Windows at 100% volume, and the DAC controls the volume depending on the output. So 100% on RCA to my headphone amp, as it has its own volume control, and 10% when choosing to play via my speakers.
Does this exist? My budget is around 600USD.
A integrated DAC/AMP combo would also work.
I can't think of any regular DAC which would allow this. The device would either need two analog volume control chips (or resistor ladders) or two DAC chips to realize this feature. This is audio interface territory. You'll need to search that sub-forum for more infos.
An easier solution would probably be to simply use two cheap DACs. One without volume control or remote to feed the headphone amp. An SMSL SU-1 comes to mind. And then another DAC with volume control for the speakers.
1. Sound quality
You might want to look at RME ADI2 products that have 2 DACs and so can have separate levels via two different outputs.
True, but for example not the ADI 2 DAC FS. You need at least the ADI 2 Pro. But that is at around 3x OPs budget, even used. Some much older models might be suitable, though.
