Pdxwayne
- Joined
- Sep 15, 2020
- Messages
- 3,219
- Likes
- 1,172
- Thread Starter
- #361
I checked the 0.2db tone examples yesterday night and it seems I could sense 0.2db down more than 0.2db up. Unfortunately that there is no test just to check for either up or down. Else I should still be able to pass 0.2db down only blind tests.Bit of a difference between your c 0.02 dB and OP 0.2dB channel difference (if we assume both ADC comparable). I do wonder if he has a lemon.
But for me, the only test that matters is if he can tell the difference between the E30 and X16 blind and level matched with filters engaged that behave the same (and I would use the ones closest to brickwall). If he can, then I would return the X16 and find something else- possibly another e30!
Before I could start the 0.2db blind tests, it was halted due to complaint from my wife all the way from upstairs! This was after I already ran the 0.5db tests prior with my stereo. So understandable that it was getting VERY annoying for my wife.....
