How do YOU know that is true?
I've actually read enough audio studies to know the tragic numbers of listener participants in most of them (vs. medical standards), and the scarcity of studies focusing specifically on this issue of coloration/FR-non-flatness detection ability. Reminder also, for the hard of hearing at the back of the class: when I see ASR bullies repeatedly skipping the step of showing what studies their bullying is based on, I am perfectly justified in saying "there are insufficient studies
to support such bullying". Basic logic should've told you that's an unassailable inference, but it seems nature has not endowed all of us with the superpower of basic logic.
“Colouration detection ability” is your made up term and it’s utterly undefined
Just like every sentence you posted was "made up", yet curiously you expect people to understand it based on a preexisting familiarity with each separate word in it, and with how words in human language work together to encode meaning. Not only that, but if you suspected your readers of any intelligence at all, you might even go so far as to expect them to recognize the same concept in different writings available in other places
even if it's named with different words! Crazy stuff, human language and reasoning - it can be shocking to the uninitiated.
First place I saw any information on it was here:
https://www.audiosciencereview.com/...-of-amp-and-dac-measurements.5734/post-127757
It was called "frequency response deviation", but also quoted from Floyd Toole as "spectral tilt".
Zero studies cited.
Then from the current thread I got this:
https://www.audiosciencereview.com/...re-finally-proven-with-abx.72444/post-2650711
Here it's called "audibility of resonances" or of "modifications of timbre". Reported tests set up by Toole & Olive seemed to have used - hold on to something -
two, four, and a whopping
six participants for separate test conditions and endpoints.
Multiple preexisting studies are cited in there, most even older and near-impossible to find, some just paywalled. What I could dig up was a '75 Fryer write-up where he reports using
"several" listeners, and since he splits them into skilled/unskilled and female/male, I guess he must've used at least 4 people. :')) A Moulana '75 paper thanks a total of
nine subjects by name right in the preamble.
Moulana, BTW, calls their study's focus "tonal colouration" - obviously "jibberish" and "trolling", right? Just like Toole's
Loudspeaker Measurements and Their Relationship to Listener Preferences, 1986, going on and on with these "made-up terms" and obvious "trolling" about "audible colorations":
there are nevertheless some recognizable patterns in this collection of findings and they can be described as follows: audible colorations are often caused by resonances in a loudspeaker system. These resonances will be revealed, in varying degrees, in both steady state amplitude responses and time-domain responses to interrupted sounds.
In order for amplitude responses to reveal unambiguous clues to the presence of resonances the measurement must have high resolution in the frequency domain and incorporate some form of spatial averaging to remove the visual clutter caused by acoustical interference. This done, evidence of potentially audible coloration will take the form of upward thrusting peaks deviating from the underlying general shape of the curve. Wide, low-amplitude bumps can be as annoying as much higher, narrow peaks. Dips in the amplitude response appear to be much less important than peaks. The technique is limited, however, in that it will not necessarily reveal the low-Q resonances 10 to 20 dB below the level of the primary signal that have been shown to be sources of audible coloration.
Well-known "troll" Floyd Toole, ladies and gentlemen.
And to finish up, later still in this thread I got this link:
https://www.audiosciencereview.com/forum/index.php?threads/“human-ears-are-better-than-measurements-”-“humans-can-hear-things-we-can’t-even-measure-”.72288/post-2651009
These are not strictly on coloration audibility but rather focus on JNDs, but I'll accept them for now considering the scarcity of direct evidence, and for the sake of my point on typical numbers of participants in audio studies:
Yost & Nielsen 1985 - can't find it, unkown number of participants
Jestead 1977 -
three participants
Johnson 1993 - paywalled
Norcross et al. 2003 - paywalled, but seems to have had
fifteen participants for at least one of the tests, based on the reposted figure (mis-cited in discussions so far as "
Scott et al."! CC:
@RandomEar )
Where did you pull 0.08 from?
Same thread you're replying to without even reading it already showed you where I got it:
https://www.audiosciencereview.com/...re-finally-proven-with-abx.72444/post-2651081
(Toole & Olive 1988 study, if assuming correlated resonances when doing the decibel arithmetic, but also seems to be corroborated by Norcross et al. 2003 if we assume JNDs are directly translatable to coloration detection ability at normal/high listening volumes.)
I wholeheartedly approve of your change of avatar, you may proceed with my full blessing.
I'm gonna guess that cites for parameters of human hearing may be found in this classic text of psychoacoustics?
In, say, oh, I dunno, maybe chapter 7?
donjoe0, get our your wallet!
That's not how forum discussions work. You either know for sure if that text answers my explicitly described concerns - but in that case you could directly quote the two numbers needed for that: lowest amplitude difference detectable by the best listener under the best conditions, and number of participating listeners in the study - OR you have no idea what the text says that is relevant to this specific discussion, in which case you're just using that link as a bludgeon and not as a proper argument, like so many others love to do around here.
