respice finem
- Joined
- Feb 1, 2021
- Messages
- 4,319
- Likes
- 8,578
Or reduce it to zero if the validation fails
Josh can ask whatever he wants as it is a rare device and that's how the market and demand works.
Thank you. It’s literally about what I value the box at now. That’s all. I’m not trying to be difficult.No one is extorting anything. The box is worth a lot more to him than it is to you. That's all there is to it.
And, of course, reduce it, and the test result, to worthless should a fault be found.Having it validated to work as advertised would actually raise its value
This ^^^ is the key point.All this should have been done before publishing the results, of course.
One more time... He hasn't done a thing I asked for. What I asked for was very little: loan the box for me to measure. I also offered $10,000 insurance if it got lost or damaged.But I also don’t think it’s a good look for ASR when somebody does a test like this, shows up to try to answer many different questions, and when not all the requests are satisfied it’s implied at the end “ you didn’t do nuffin’ for us.”
That's the bad look. Please don't dare putting this at my feet. The man has no ethics to demand nearly $4,000 for a box he paid $1,200 for, especially when we look at the need for the community to be served by this kind of analysis.
So? You make it sound like he is not a member here. And participating in this thread.On the other hand, I think it should be taken into account that Josh has not started this thread at ASR.
In case it needs reiterating, as I said in my post above:As I said above, I will accept my actual documented costs for the box, plus an equal donation to my local SPCA.
No, I do not make it sound like he is not a member here. I am saying you hardly have a legal right to ask him to send the box for test to you, based on subjective results he published elsewhere. You only may consider if you trust his results based on known data. I am saying that to me the published data are unsatisfactory and as such his test result is untrustworthy.So? You make it sound like he is not a member here. And participating in this thread.
The heck you talking about? Legal rights?No, I do not make it sound like he is not a member here. I am saying you hardly have a legal right to ask him to send the box for test to you, based on subjective results he published elsewhere.
Considering that you'd prefer to keep it, Amir offered you a substantial guarantee for the loan. Would you accept the loan plus, say, $200? You'll make money either way, and you'll keep the box.In case it needs reiterating, as I said in my post above:
Should the very idea of me receiving any money — even what I paid for the box — be the issue, I’d happily take the Sandy Denny CD box set, essentially trading an object I value (the ABX box) for one I’ll value at least as much (the Denny box) plus the SPCA donation.
I am offering it to you where I will (quite literally) not make even a single buck, and it will benefit a worthy charity.Josh on the other hand, seems to be after making a buck.
One question. You mentioned that there is published data of the Matrix X-Sabre Pro MQA DAC has a non-inverted output. Can you direct me to that published data, showing the waveform of the in and output using the RCA output?I am offering it to you where I will (quite literally) not make even a single buck, and it will benefit a worthy charity.
With headphones I can hear a very small change in the lower tones. But when looked to the waveforms in Audacity then the second part had not really the inverted sawtooth. Therefore it is not a valid test file for polarity inversion.I have been very busy working today, so no more from me. These signals also seems to make my ears ring a bit...I do not want that...
If someone wants to hear an easy one it is this short part of a filtered sawtooth wave, first with correct polarity and then shifted to inverted polarity. Just say if you can or cannot hear the shift in timbre.
Dropbox
www.dropbox.com
About right.
