DeltaWave v2.0.13, 2026-08-04T16:52:14.4091845+02:00
Reference: MT_orig_96k_PCM24.wav[L] 1000000 samples 96000Hz 24bits, mono, MD5=00
Comparison: multitone_bt.wav[L] 1000000 samples 96000Hz 24bits, mono, MD5=00
Settings:
Gain:True, Remove DC:True
Non-linear Gain EQ:False Non-linear Phase EQ: False
EQ FFT Size:65536, EQ Frequency Cut: 0Hz - 0Hz, EQ Threshold: -160dB
Correct Non-linearity: False
Correct Drift:True, Precision:30, Subsample Align:True
Non-Linear drift Correction:True
Upsample:False, Window:Hann
Spectrum Window:Kaiser10, Spectrum Size:262144
Spectrogram Window:Hann, Spectrogram Size:4096, Spectrogram Steps:2048
Filter Type:FIR, window:Hann, taps:8192, minimum phase=False
Dither:False bits=0
Trim Silence:True
Enable Simple Waveform Measurement: False
Discarding Reference: Start=0s, End=0s
Discarding Comparison: Start=0s, End=0s
Initial peak values Reference: -2.647dB Comparison: -2.227dB
Initial RMS values Reference: -15.043dB Comparison: -15.046dB
Null Depth=12.397dB
Trimming 222 samples at start and 50 samples at the end that are below -90.31dB level
Phase inverted
