- Joined
- Jan 13, 2025
- Messages
- 43
- Likes
- 103
Thank you for taking the time to read my article. As I mentioned in it, this test was born out of my own “soft objectivist” desire to see what I could and couldn’t hear. I went to the trouble of acquiring the ABX Comparator because I wanted the answer for myself, and I’d have been happy with either a clear positive or a clear negative result. I’ll also note that my article’s title and text are deliberately less provocative than the title of this thread. I’m not making any claims beyond my own listening.
A few specific responses:
- On filters: I meant to mention this in the article. I always use linear sharp filters on any DAC with selectable filters, including the RME and Matrix. I upsampled every test track to 24/96 offline, before playback, in order to push any top-octave filter roll-off differences above the audible band.
- On timing and switching artifacts: both DACs were fed from the same USB-to-SPDIF converter (a Mutec MC 1.2), so the digital front end was identical. The Van Alstine inserts a uniform click through the output on every switch—the same click whether it changes the source or holds it. It’s impossible to switch between X and A/B without hearing the click first. I didn’t detect any timing differences, nor were those what I listened for. I had no desire to “pass” a test for technical reasons. For example, I can pass a software ABX test between hi-res and Redbook audio by exploiting low-level differences such as noise floor, but I don’t consider that a real or meaningful pass. For that reason, I excluded any DACs with obviously higher noise floors, so that a positive result couldn’t be chalked up to noise-floor discrimination rather than the differences I was actually investigating.
- On the unit itself: my Comparator is newer than the one in the Dagogo review and includes the relay revisions. I confirmed the specific model with the seller, then verified it with the box’s designer, Dan Kuechle, before buying.
- On how the box works: Each blind test is eight rounds. In each round you’re presented with X—randomly either A or B—alongside the known A and B sources, and you identify which X is. This is the same ABX protocol as the software tools you may have used to compare audio files. The only difference is that the Van Alstine implements it in hardware, which is what makes it possible to ABX physical devices like DACs rather than files.
- On the box’s transparency: the Comparator does no processing. It only passively attenuates. Kuechle covers this in the manual.
- On whether the differences matter: I don’t think what I heard was irrelevant to the music. But I also don’t claim the differences are large, that most people would hear them, or that they’d find them meaningful if they did. I touched on this near the end of the article, and whether such differences are worth caring about is exactly the question I tackle in a follow-up.
