- Thread Starter
- #21
Agreed, but we live in attention economy.(this thread's topic name is bad)
So you can get a perfect score by not at all listening to the DUTsThere is mention that in the version the author used the relays for switching between A and B sound different, and that the manufacturer fixed this for later versions.
Mathematician Matt Parker once wrote ‘it’s amazing what you can prove if you’re prepared to ignore enough data…’So you can get a perfect score by not at all listening to the DUTs![]()
That's the part I always think of. I assume various manufacturers offering a "house sound" of sorts will manipulate the output stage.You make a good point here (given I understood you correctly) - The DACs are either transparent or you can tell them apart. Right? If you've managed to tell them apart, they are obviously not transparent or not sufficiently transparent.
No one ever said it's never the case you can here the difference. The point was - if you can hear it (and you shouldn't), it's not working properly. Other point being that the difference maybe coming from an output stage, some gain or something and not converting zeros and ones into an analogue signal.
There's no proof of that even existing, so... Why assume something like that? The output matters. The measurements capture the output. Why should we care about output stages, capacitors, op amps or whatever else if the resulting performance is essentially identical? It's a repeating discussion even here on ASR which I do not understand. I have seen no logical argument which supports it. If the end result at the output RCA/XLR terminals is identical, why focus on the parts inside the little black box? The output is the only thing which matters for the actual sound, because that is what we listen to. Everything else is only relevant to other qualities like longevity.That's the part I always think of. I assume various manufacturers offering a "house sound" of sorts will manipulate the output stage.
I'm just glad DACs are as good as they are now.
I can thus expend more time, effort and money on recorded and live music.
The point is, if someone can reliably differentiate between to units/boxes containing a DAC chip, I assume it's not due to the chip but something done at the output stages as we know there's been dead transparent DAC chips for decades now. I have not followed the objective testing of it via Amir and co as that's about as interesting to me as watching paint dry. If say the testing being discussed in the OP is a legit example of audible differences, is that due to the chips used or something else? I assume it's due to the something else part of it in the audio signal at this time. I also don't put it past some manufacturer to create a "house sound" by altering output stage, but I will take your word for it that it has yet to be demonstrated via objective testing.There's no proof of that even existing, so... Why assume something like that? The output matters. The measurements capture the output. Why should we care about output stages, capacitors, op amps or whatever else if the resulting performance is essentially identical? It's a repeating discussion even here on ASR which I do not understand. I have seen no logical argument which supports it. If the end result at the output RCA/XLR terminals is identical, why focus on the parts inside the little black box? The output is the only thing which matters for the actual sound, because that is what we listen to. Everything else is only relevant to other qualities like longevity.
If someone could differentiate them, there would have to be a measurable and audibly significant difference. In that case, why attribute that difference to "output stages" or any other specific part, for that matter? It could be a mix of a dozen small differences. Why assume the chips or their settings would not be the cause? Sorry, but I do not follow that reasoning. If a difference exists, it can be in any or multiple part of the chain inside the little black box. There is also no reason why "house sound" should be specifically due to output stages. Manufacturers can simply implement their own reconstruction filters - better DAC chips provide at least one slot for custom filter designs. Put in a super slow roll-off filter and BAM: "Mellow and relaxed house sound"The point is, if someone can reliably differentiate between to units/boxes containing a DAC chip, I assume it's not due to the chip but something done at the output stages as we know there's been dead transparent DAC chips for decades now. I have not followed the objective testing of it via Amir and co as that's about as interesting to me as watching paint dry. If say the testing being discussed in the OP is a legit example of audible differences, is that due to the chips used or something else? I assume it's due to the something else part of it in the audio signal at this time. I also don't put it past some manufacturer to create a "house sound" by altering output stage, but I will take your word for it that it has yet to be demonstrated via objective testing.
Seems like a good possibility to run down.This all strongly suggests that for comparing line-level signal sources the comparator itself produces some audible artefacts between the A and B paths, and that these are sufficient to allow clearly distinguishing the two.
Because according the powers that be, chips have been audibly transparent for decades now. As you point out, there are various places along the signal they could play with that to offer something different, yes, I assumed at the output stage. First, we'd have to establish some can actually differentiate them under controlled conditions (and that's being debated here now) and then we'd have to figure out why/how.If someone could differentiate them, there would have to be a measurable and audibly significant difference. In that case, why attribute that difference to "output stages" or any other specific part, for that matter? It could be a mix of a dozen small differences. Why assume the chips or their settings would not be the cause? Sorry, but I do not follow that reasoning. If a difference exists, it can be in any or multiple part of the chain inside the little black box. There is also no reason why "house sound" should be specifically due to output stages. Manufacturers can simply implement their own reconstruction filters - better DAC chips provide at least one slot for custom filter designs. Put in a super slow roll-off filter and BAM: "Mellow and relaxed house sound"![]()
Yes. And it also would be good to have test files recorded by a good ADC like Cosmos and analyze it. Otherwise, it is difficult to make a conclusion based on descriptions only.I think the next good step would be to measure the comparator.
Unfortunately science history is littered with examples of sometimes quite prestigious people who made up or finagled results. But science overcomes this through replication. A one off study has little weight until another lab follows the same protocols and gets the same or similar results. Usually faked results are too perfect. Error is almost impossible to eradicate in any experimental set up.First impression: no mention of any settings on those DACs. I mean those are complex processors and not one-way headphone amps. Factory defaults out of the box? Customized boxes? Which filters have been used?
Second thought: people never make stuff like that up. That's a thing of the art world. No need for any proof it all did actually happen.
About filters, in order to eliminate their effect as he says, all material was 24/96 (the one that wasn't was upsampled with XLD.Based on statistics alone, I am extremely sceptical of these results. I have done a couple of "easier" ABX tests, for example between a signal where there was a small gradual drop of up to 0.5 dB in the response above 6 kHz. Even with these comparatively major differences, I did not score 10/10 in each test, repeatedly again and again. It is hard to distinguish such tiny differences and your ears occasionally will fail you. So 54 out of 56: I am extremely, extremely sceptical of that result, based on the numbers alone.
That being said, there's two major things not adressed in the article:
Soooo... This delay thing needs to be clarified. Otherwise, this looks like a false positive to me.
- Choice of reconstruction filters: The X Sabre Pro for example uses a slow roll-off filter by default, most other DACs in the test use a linear fast roll-off by default. Yes, the material was supposedly 96 kHz or upsampled to that. But I would nevertheless expect such essential settings to be listed and - if he was looking for a fair comparison - I would expect the author to select similar or if possible identical filters on all DACs.
- Delay: This is a big one. According to what I have seen in the article, the DACs were not time-aligned (-> directly fed by the same S/PDIF source). Due to the likely different filters in play, the effective delay between the DAC outputs will vary between around 150 µs up to roughly 900 µs, maybe more. Since humans can distinguish delays larger than around 7 to 18 µs depending on which trigger is investigated, this could potentially allow anybody to ABX these DACs under the given conditions. Simply because there's a time difference of multiple hundred microseconds between many pairs of them, or maybe all pairs - we can't know because as far as I could see, the reconstruction filters were not listed for any comparison and delays were not measured.
