- Joined
- Dec 12, 2019
- Messages
- 18,117
- Likes
- 41,875
Yup.What causes doubt for me is extremely high success rate.
You're not joshing.Obviously I am not Josh.
I reckon many if not most of us have been through the peer review process -- likely as both reviewer and 'reviewee'.![]()
I wonder how many of the people accepting the story without questioning have tried an ABX to know how hard it is to get 100% even when you are clued in and there are small but definite audible differences.
I didn’t see a lot of the “sinister agit-prop” stuff, I think mostly people are engaging and asking questions because this is both a good faith effort AND goes against a mountain of contrary evidence. There hasn’t been any ridicule.I’m baffled that people here are treating this test as some kind of sinister agit-prop triumph for subjectivists that challenges the integrity of the audio science world and needs to be mobilized against.
The minor differences the tests claims to have successfully discerned and identified, insofar as the test write-up makes clear what they were (and it doesn’t make it very clear *at all*), are seemingly so trivial and marginal that the significance of the test, even if was robust and valid, remains obscured inside a dense fog bank of uncertainty and extremely indeterminate import.
The author has some further explaining to do, and has promised he will.
I'm reluctant to start accusing or anything, because I think that lowers our chances of ever getting corroboration from Josh, and we don't have anything that positively suggests fakery per se.Totally agree to Your point of view. What brings up my couriosity is the motivation to do that kind of test and publishing it. We know, samples for such tests cost a lot of money, as well as that 'miracle-AB-box', so there is some investment to begin with. If this was really done, I would have expected some participation into the discussion here. But: no.
And no (as suggested and alway presented in Your reviews) images of DUT, ABX-box, no files ... nothing.
Fake?
This is where positive controls would have come in handy.I wonder how many of the people accepting the story without questioning have tried an ABX to know how hard it is to get 100% even when you are clued in and there are small but definite audible differences.
And, again, for anyone reading this and thinking ASR folks are negative nancies who don't want there to be differences in DACs... my favorite possible outcome is we find an un- or under-documented mode of distortion in DACs and fix it in future DACs. That would ultimately be the point of all this, right?
The variable resistor is the load for the source/DAC (voltage divider). Its non-linearities directly distort the output of the DAC as evidenced by how the same happens with distortion created in dummy loads for amplifier testing. An active load is just not going to be clean and certainly not for state of the art DACs.That is the nonlinearity (==precision) of the resistance steps in rheostat mode (thus with wiper influence), not of the signal passing through in potentiometric mode (EDIT: actually we don't know which mode is used, it could well be rheostat mode with a fixed upper resistor, looking at the layout).
Two factors are in play here:I am not following how the linearity of the digital pot is a problem, as long as the setting used gets to 0.1dB matching and the resistance is stable.
Amir’s record on the Archimago DAC challenge is new to me and worth considering as well.
I don't know how much the resistance non-linearities come into play for line level signals and the digital pot (certainly something to consider), but your (2) is a good point I had not considered. If a single setting operation is controlling two pots in two source channels then I do think that sounds like it might be an issue depending on how it was checked. I wonder if @Josh83 was just checking the matching of L in A against L on B, and also R in A against R in B, when he says he made sure sources were within 0.1 dB.Two factors are in play here:
1. Non-linearities in the "resistance" provided. An active load like this as I noted, is going to have distortion and hence the reason we don't use them for amplifier testing. They are OK for DC and non-critical applications, but not for high resolution/high fidelity applications.
2. The step you use, unless identical in both paths, will present different non-linearities.
If these were not an issue, this would be used as a volume control in products but they are not. Instead we have specialized VCAs (voltage controlled amplifiers) specially designed to be linear and keep distortion low. But even those devices can't keep up with state of the art DACs and will have level linearities.
Note that even standard resistors will have non-linearities.
Relays sequence/sounds can give cues as to either A or B is being played. SeeInteresting how the perceived impact of the switch seems to have well, switched.
Usually it’s the “subjectivists” who say DBTs are flawed because “the switch makes everything sound the same”
Now the “objectivists” are saying the test is flawed because “the switch makes everything sound different”
At such cost per pcs, one would need to sell at least 10 units to cover development costs. I’m dead serious.I'd gladly pay $2000-3000 for such a device. I'm dead serious.
I would not draw that conclusion though. I can see people wanting more functionality or balanced in/out etc and perhaps a more secure (so one cannot fabricate results afterwards) way of reporting the 8 attempts (I assume this would be displayed as input and chosen value for each attempt ?).It seems like now the ABX comparator itself is being considered as "not good enough".
The line level part is easy enough to design if you are happy with the performance of the TI PGA2311 volume control (-107dB THD+N). Using an ADC for calibration and a switched resistor chain we can get to 0.02dB level matching between DUTs, _and_ also level match each DUT's right and left channels if you want, to eliminate that possible cue. Controlling things through a microcontroller allows for automation of the level matching and also randomising relay switching order and delays.It seems like now the ABX comparator itself is being considered as "not good enough". As someone who uses it regularly, I have found it to be quite helpful. Though, I do wish I could somehow do blind testing with digital sources. Specifically, HDMI, for when I test preamps.
That said, I would absolutely welcome a better version. I'll put my money where my mouth is, too.
I'd be happy to commission someone here to build *the ultimate ABX box* with better circuity and the addition of digital I/O. Also, silent switching. Take the current Van Alstine and let's beef it up to the point of future-proofing for the next decade. I'd gladly pay $2000-3000 for such a device. I'm dead serious.
I like the unit being remote controlled but having the results captured via SD card or via computer would be icing on the cake. Hell, even a way to directly tie in a SOTA sound card for capture, if we are gonna get wild. But, those would be pipe dreams.
I'll put up the money once the design is agreed upon. I don't know where the starting point would be but the challenge/offer is there if someone wants to take it on feel free to email me and let's talk: [email protected]
Oh, the Van Alstine's ABX box has too many speaker selectors. So this could be cut from 3 to 2.
Sincerely,
Erin
