Hi, Amir. It was good to meet you at AXPONA. I hope all is well.
I’ll start with the bad news first. I do indeed have the Van Alstine ABX unit and I understand why you’d be interested in testing this. But I have no desire to ship it anywhere. As you know, these are very hard to find and I’m not willing to risk something getting lost in shipment. Even though I know it’s unlikely to happen, I'm not willing to take that risk.
I’ll give you my two cents with respect to the ABX unit and Josh‘s article. Bear with me because this is going to be long-winded, but I have a point. I promise.
I’ve had my comparator for about three years now. I don’t use it often, but I consider it an essential part of my electronics reviews. In fact, I am currently using it to do some blind comparisons between a clone McIntosh amp and a real McIntosh amp.
While I have yet to use it to compare DACs, I have used it to compare preamps, amplifiers and speakers. What I can tell you is that when it comes to electronics the only time I’ve ever been able to reliably tell a difference is with an amplifier that has high output impedance.
I used it when I reviewed one of the newer WiiM amplifiers and compared it to the previous version without PFFB. I could hear a difference, but the data gave me insight as to why. I also used it to compare the NAD C3050 against one of Dayton’s hybrid tube amplifiers. There was definitely more “heft“ in the midrange with the Dayton. Looking at the frequency response with the speakers connected at the amplifier, it was pretty easy to tell why this was the case. The Dayton had had a boosted upper midbass and lower midrange.
The most audibly different test case, however, was when I compared a McIntosh MC 275 tube amplifier to a Prima Luna tube amplifier (I forget the model number). Both of these tests compared a low output impedance versus a high(er) output impedance amplifier. In short, the fact that I heard a difference - even in blind ABX testing - made perfect sense.
Worth noting is that the latter comparison - between the two tube amplifiers - was the hardest to perform in a meaningful way because the Prima Luna amplifier had such high output impedance that the frequency response shaped it as much as 3 dB in some regions, depending on the speaker was driving. While the McIntosh, with its incredibly low output impedance, was not low dependent, and thus the frequency response was unchanged. This made it practically impossible to do true “level matching”. I discussed this in a video I made last fall about why amplifiers*can* sound different.
In cases where I heard a difference, I was able to track down the difference with some basic measurements. However, outside of these cases where there is a perfectly reasonable explanation for the differences that were legitimately heard in ABX testing, I have yet to hear a difference in well engineered electronics.
I say all that to say this:
I am highly suspicious of Josh’s ABX test results. The article is very well written. And it seems like he took all the necessary steps to level match and set the test up the right way. But his result, with him getting practically 100% over 112 tests, seems extremely unlikely assuming everything is in order and indeed, the only variable is simply the DUT.
I don’t want it to sound like I am bashing Josh or his test/article. In fact, it’s one of the more thorough pieces I’ve read in years. It’s possible everything was done perfectly and the results wouldn’t change no matter how many times you ran the test. However, I think his results should’ve been questioned before being published. To get that kind of accuracy, regardless of how much ear training* or experience you have seems highly improbable. And that is putting it mildly.
* like Josh, I also use Sound Gym for my ear training.
It seems to me the more likely answer is that there’s an issue in the setup somewhere. I don’t know what that would be because as far as I can tell everything looks like it was done correctly. But without testing his exact unit or at least having the actual measurements from each of the DUTs outputs, we can only speculate that they’re is a set of issue.
And that leads me to this: testing my unit would not guarantee his is not flawed, if that’s the goal. Sure, if they are all a bit off spec then you could surmise that from testing mine. But mine is also the latest version which was manufactured in December 2022. We don’t know what version Josh’s is, do we? Let’s say mine shows a clean bill of health. That doesn’t mean that his isn’t faulty in some way.
As I said above, I think the best bet is for Josh to publish all of his data showing the measurements from each of the units and testing rounds. If nothing else, at least simple frequency response will tell him/community if there is any deviation there or output levels that might cause something. It’s also worth noting that doing this testing could be done to simply try to understand why differences were hurt. Not necessarily to Hoke holes in the methodology. I genuinely see this as a great opportunity for learning. Other learning that there is a flaw in the test set up and/or learning why there were differences heard.
Funny story, though, if I am not mistaken I was actually going buy the same box from the same gentleman in Washington. If that is the case, then his unit was an older model. But the current owner can test that by simply powering the unit on and reading the display on boot up.
— As an aside, I reached out a couple months ago to see if you would be interested in testing my McIntosh C55 stereo preamp before I sold it to a friend of mine. I sent you an email and a text but maybe I just have the wrong contact info for you. I’ll keep this one for future needs. —
TL;DR
I’m not interested in shipping my unit. It’s too risky for me.
Testing my unit would not guarantee the performance of Josh’s.
I think Josh‘s results are too good to be true and further analysis is needed.
I personally have no vested interest in his results other than the scientist in me wants to know they are indeed correct.
Take care,
Erin
PS: please forgive any grammatical errors. I’m using Siri and she still hasn’t figured out my southern accent.
PPS: You are more than welcome to copy and quote me on the forum if it saves you from having to summarize this email.
