Hi everyone. Excited to have found an audio community that understands and appreciates signal processing and physics
I'm looking to upgrade my $70 gaming headset to something a little more premium. After much research and debate, I've (mostly) settled on the HD 490 Pros. They seem to be a good fit for my use case (gaming, classical music, teams calls) based on their transparency, sound stage, and price point. Side note: planning to get an Antlion Mod Mic USB 2.
The main piece that's missing is a DAC+Amp. My PC's motherboard audio quality isn't great because it picks up a lot of junk, and the driver and interface even worse. My wishlist is as follows, roughly in order, though none are dealbreakers:
* Can drive the 490s with good transparency
* Slim height as I'll be mounting it under my desk
* Balanced output
* Powered over USB (i.e. no additional power cable needed
* $200ish range
* No volume knob (mainly for compactness).
After much searching and requesting recommendations on reddit, which was not very fruitful, I haven't found anything that checks all the boxes. Maybe nothing exists, but nonetheless I'm hoping to get more suggestions.
I was a little surprised that I couldn't find an open source DIY design given that the market has converged to a small number of USB controllers, DACs, and signal chains. My searches only turned up a couple of 5-10 year old abandoned projects. Would be happy to spin a PCB and do some soldering if there were a design readily available.
Right now, top of my shortlist seems to be the iFi Zen DAC 3 though it's a bit bigger than I'd hoped. Fiio K3S or K11 are also options but I hesitate to buy from a company that ships a product with a "24bit" R2R with discrete 0.1% resistors...
Thanks!
* Balanced output
* $200ish range
Thanks!
