alienaudio
- Joined
- Apr 15, 2026
- Messages
- 6
- Likes
- 2
Hello ASR members,
Looking for community feedback on a desktop DAC/amp shortlist. I'll try to keep this focused.
Setup context -
Source: Apple Mac Studio via USB, streaming Spotify / Apple Music / Roon
Current DAC: Chord Hugo 2 — being retired due to persistent Apple Mac recognition failures (USB dropouts, won't appear as audio device after wake/power cycle, unresolved despite cable swaps, firmware checks, and Chord's own suggestions)
Headphones -
Speakers -
Planning to add active desktop speakers (KEF LSX II LT or Kanto ORA) driven via the preamp outputs of whatever DAC/amp I choose.
Shortlist (in current preference order) -
Specific questions -
Setup context -
Headphones -
- Focal Celestee — 35Ω / 105 dB/mW (easy load)
- Abyss Diana MR — 30Ω / ~93 dB/mW planar; Abyss recommends 200mW–1.5W
Speakers -
- Topping DX9 Discrete
- RME ADI-2 DAC FS
- Schiit Jotunheim 3 + Mesh DAC module
- Topping DX5 II
- SPL Phonitor X
- The DX9 Discrete is my current lean — is the headphone amp section genuinely sufficient for a low-sensitivity 30Ω planar, or does it measure/perform better into higher impedance loads?
- The RME ADI-2 FS has current limiting (~260mA/channel per the manual) and some users report it feeling dynamically constrained with planars. Is this audible at normal listening levels with a 30Ω/93dB load, or is it a non-issue in practice?
- The SPL Phonitor X has received mixed ASR measurements (notably the headphone amp section at low impedance). Has this been revisited or is the measurement concern considered settled?
- For the speakers: any practical reason to prefer KEF LSX II LT over the Kanto ORA when driven via analog RCA preout (bypassing the KEF's internal streaming)?
- Mac Studio USB reliability — power cycling and device recognition
One issue that's driving this upgrade is the Hugo 2's unreliable Mac recognition after power cycling.
So for any of the shortlisted units (DX9 Discrete, ADI-2 FS, Jotunheim 3, DX5 II), are there known Mac Studio USB stability issues — particularly around power cycling, sleep/wake, or hot-plugging? I haven't found anything in my research but I could have easily missed it. The RME and Topping units are USB Audio Class Compliant (driverless on macOS) which I'd assume makes them more reliable in this regard, but happy to be corrected. The Schiit Jotunheim 3 with Mesh DAC uses Unison USB which Schiit also claims is Class Compliant — any real-world Mac experience with that specifically?
