Dac + Amp Akg K712 Pro
chechu21
Good morning everyone!
I have an Xduoo Xd 05 but the connector is broken. Now I want to buy myself something better. What I do not know whether to buy the dac and the amp separately. Or take advantage of the xduoo dac and buy only the amp. What options do you recommend? My maximum budget is 300 dollars. Will it be enough to get the most out of the Akg K712?
Thank you!
Schiit Asgard with installed DAC or Asgard with a separate DAC.
smsl sp200 + smsl m300 mk2 ;)
If you're in USA get JDS labs Atom amp and Atom DAC, Atom DAC if you only need a USB support. If you want optical or coax then Topping E30 as a DAC.
Anywhere else wait a bit till Topping L30 becomes available and get it plus Topping E30 DAC.
