DAC ABX Test Phase 1: Does a SOTA DAC sound the same as a budget DAC if proper controls are put in place? Spoiler: Probably yes. :)
Just choose a fine measuring properly engineered dac from the list that Amir has measured.
Sure but SINAD doesn't give whole picture, THD is also plays role
They are different ways of expressing the same thing.
human ear is not very sensitive to changes in dB across it
On the contrary, that's one of the things that ears are most sensitive to.
To give an idea, we could listen to 8-bit or 6-bit converted sample to know how the sample sounds when we loose information, and look for same characteristic but way way more subtle.
The difference is noise floor (recordings are dithered), not "clarity."
Thats why I think to be able to tell diference between DACs, you must have rest of the setup really close to perfection so its distortions won't cover how DACs "plays".
Can you specify which exact setup do you think would be 'close enough to perfection' so that you could hear differences between various DACs?
Note that e.g. the $28,000/pair state-of-the-art KEF Blade 2 Meta loudspeakers (full measurements) have best-case -60dB multitone distortion (equivalent to only ~10bits resolution), even going up above -40dB (~6bits) in higher frequencies and higher volumes. Some speakers may do better, but definitely not better enough.
Basically any non-broken DAC beats this performance - including the 20$ FiiO Taishan D03K from post #1.
Some headphones and IEMs can do significantly better (THD levels at about -70dB to -80dB), but again not close to the level of well-measuring DACs.
Additionally, most residential rooms won't have more than about 70-80dB (~11-13bits) maximum available dynamic range (limited by ambient noise on the bottom, and by human pain threshold at the top). In practice it will be even less, because most people wouldn't (shouldn't? :p) come close to the pain threshold while listening.
Some might use these points to argue that we shouldn't worry too much about (reasonably competently designed) DACs at all, given than most produce better than 16bit resolution. :)
True but I don't think diffreneces in DACs are in tonality, the frequency response is almost identical across all of them
Except the frequency response was not the same in the two DACs used for this ABX test, please refer to comparative measurements in post #1.
and human ear is not very sensitive to changes in dB across it
Actually, research has shown that human ear is quite good at identifying low-Q frequency response deviations in ABX tests with fast switching, even when low in level. The likely problem in this specific case is that the FR difference between these two DACs is at very high frequencies where human hearing sensitivity is naturally lower, and degrades/is lost as we get older.
Anyway with this method what you evaluate is distortion of your headphones, amplifier, your DAC, A/D conversion in the middle, and one of other DACs (tested). Every step introduce its own distoritions, and I think we can assume that bigger distortions covers smaller.
Frequency response deviations are linear and additive, so any system with sufficient bandwidth will show FR differences between these two recordings of DAC output.
Harmonic and non-harmonic distortions are indeed subject to masking and (assuming a system with optimal gain-staging) distortions induced by the DAC will be almost certainly hidden by (any) headphone or loudspeaker you use - regardless of other components in the reproduction system.
Please note that post #1 provides much more measurements than just SINAD, as well as references to the full measurement suite of both DACs and the ADC.
I got it correct 6/16 times, quite bad :)
Quite normal I would say . Quite sobering when you realise how "bad' things need to be to negatively impact our enjoyment of the music .
Think the message for me is buy whatever you like at whatever price you're prepared to pay. Just don't assume that has any bearing on the playback quality you perceive (unless it's transducers and room treatment buys )
I just stumbled upon the reported results in post #196. A plot of these results vs. a normal distribution looks like this:
So it's very obvious that there is no big deviation. I ran a couple of tests against the normal distribution, which gave the following results:
I'm not an expert in statistics. Assuming I tested the dataset correctly, my interpretation would be that the probability that this isn't normally distributed data is at or below 0.132%. This is based on the worst case result from the list above and assuming that the worst-case test (Anderson–Darling) is also the most discriminating one.
Oh, I would like to point out the 100% correct testers. Perhaps they are goldenears or cheated using some helping analysing software/gear - but even if they cheated the difference was detectable despite the extra AD round the signals were subjected to, so at least there is no masking problem (at the extra AD stage of this test).
Unless they lucked out. But that is very unlikely.
I think it is mathematically unlikely. With 16 choices there is one chance in 65536 to get a random perfect score. That 3 participants out of just 500 got it is definitely not random. Whether they used an analyzer or their ears it is another matter, but this not random.
