D&A Alpha DAC & HP Amp Review
Rate this Balanced DAC & HP Amp:
    Votes: 0 0.0%
    Votes: 2 1.5%
    Votes: 30 22.1%
    Votes: 104 76.5%
This is a review and detailed measurements of the D&A Alpha balanced DAC and headphone amplifier. It was sent to me by Shenzhen Audio and costs US $399.
No, you are not seeing double. What I tested before was the Alpha Pro. The non-pro version has the same distinct white LED and clear front panel with labels that are kind of hard to read. Otherwise, it is a very simple unit to use. I especially like the brightness of LED ring around the volume control changing proportionally to its setting.
I upgraded it before testing it. In the interest of digging my way our of mountain of gear here to test :), I focused my testing on balanced output unless said otherwise.
D&A Alpha DAC Measurements
Our usual dashboard produced stunningly good results:
We are talking a fraction of a hair below best there has ever been:
Noise performance is stellar as it should be to get the above result:
Max output is higher so it is able to generate even better results if your amplifier can handle it:
D&A Alpha Balanced Stereo DAC and Headphone Amplifier THD vs Level Measurement.png
Multitone shows off the incredibly low distortion products:
D&A Alpha Balanced Stereo DAC and Headphone Amplifier Multitone Measurement.png
But we do have a hint of "ESS IMD Hump:"
You get that small step up in distortion around -40 dBFS.
Jitter output is clean as a whistle and nicely shows off the multiples of 250 Hz deep in the J-test signal:
D&A Alpha Balanced Stereo DAC and Headphone Amplifier Jitter Measurement.png
The DAC doesn't expose filter setting which is fine by me as the default is what I expect:
D&A Alpha Balanced Stereo DAC and Headphone Amplifier Filter Measurement.png
D&A Alpha Balanced Stereo DAC and Headphone Amplifier frequency response Measurement.png
Edit: forgot to show THD+N vs Freq:
D&A Alpha Balanced Stereo DAC and Headphone Amplifier THD vs Freq Measurement.png
D&A Alpha Headphone Amplifier Measurements
The Pro version had a superb DAC as well but fell short in headphone amplifier department. Not here:
D&A Alpha Balanced Stereo DAC and Headphone Amplifier Headphone 300 ohm Measurement.png
That's huge amount of power into such a high impedance load. But it gets better:
D&A Alpha Balanced Stereo DAC and Headphone Amplifier Headphone 32 ohm Measurement.png
We are talking 8+ watts into 32 ohm load! Not only can this amp push out voltage, it can back it with ton of current. It should not have trouble driving any headphone to ear bleeding levels.
Lacking an analog negative gain, it only produces average noise results using unbalanced out (balanced was worse):
D&A Alpha Balanced Stereo DAC and Headphone Amplifier Headphone 50mv SNR Measurement.png
EDIT: I see that the specs say low gain is negative so not sure why the results are not better.
D&A Alpha Headphone Listening Tests
Ok, I predicted the Alpha could play loud but didn't think it could get this loud... Using my Dan Clark Core headphone at or above 12:00 in high gain, not only did it threaten my hearing, but managed to threaten the headphone with risk of drive damage! I could hear the bass notes to go from clean to increasingly distorted while my inner ear started to tingle!!! Stuff I do for you all! :D
Set it at 11:00 and heavy bass demo material makes you feel like your head is inside an orchestra playing not only superbly dynamic, but incredibly clean. Detail hangs out in the air inside your skull like nobody's business. See, I can write flowery subjective sentences without use of AI! :)
Seriously, the Alpha takes away the worry about not having enough amplification for any headphone while producing stunning fidelity.
I am amazed that D&A when down half in price, took the word "Pro" out of the name and produced a state of the art DAC and headphone amplifier. On the latter, it is able to pump out incredible amount of power, removing any thought of the amplifier getting distorted. If you hear something unthwart, it is your headphone or source, not the Alpha! Your only worry will be hearing damage so I suggest you stay with medium gain unless you are sure you need the high gain.
Listening to the combination of Dan Clark Core and D&A Alpha once again reminds me how far we have come in pushing the state of the art in sound reproduction, albeit by using a headphone. Aha moments come back to back in the same track in the matter of seconds!!! And all this for $399 in a distinctive packaging.
Company deserves especially kudos for improving performance so much yet reducing the retail price significantly.
I am happy to recommend the D&A Alpha DAC and headphone amplifier.
That's a cool looking front panel! Reminds of of the Hifi Rose look a little bit. Measures pretty good as well!
So you can compare the Non Pro VS Pro
The retro design makes think the new Fiio Level 1 amp BTW)
Looks great, totally smash all the performance test, does not cost too much.
Great review.
That's just a silly amount of power! And available with a State of the Art DAC for $399! This stuff just keeps dropping in price for what the buyer is getting. It's just laughable how much $400-500 buys in this market nowadays. Anybody wanna spend $2k for a Chord Hugo?
Thanks again for another great review, Amir.
I don't understand why you always say very nice attenuation above 24kHz for a 44.1kHz sample rate test signal.
It is only 10dB filtering before Nyquist. That is not "very nice"
Compare that to the Chord Mojo2 / Qutest / Hugo TT2 you've measured.
Something like the below qualifies as technically "very nice", not 10dB filtering
I say that because it is true: It is nice attenuation above 24 kHz. Without it, you get this kind of wideband response:
This is an independent thing than brickwall filtering at Nyquist. There, your content is already rolling off many dBs and therefore, doesn't need much filtering in the DAC.
For a 44.kHz music there is nothing above 22kHz so I don't understand the comment above 24kHz?
If you do a 48kHz test signal, the attenuation above 24kHz will not be "very nice" ?
If you have the Alpha can you do a 48kHz test?
Nice retro look but DX5 II provides more bang for the buck
Too many good choices for DAC/HP amp. Wish it had PEQ settings (though Topping seems to have a hard time to optimize the software). I like the somewhat retro design. Hope the lights aren't too bright. Well, my cheap DL200 is still going strong and it's fun to think about what to get if it stops working.
There is as you see in the measurement. The images spread in ultrasonic with peaks at multiples of sampling frequency:
With 45 KHz bandwidth, the wideband THD+N vs frequency picks up these mirror images.
@amirm looks like we’re missing THD+N(F).
Shoot... We are discussing the topic and here I forgot to post that graph! Just added to the review:
Full attenuation at 24kHz means that aliases only occur above 20kHz. So while technically not "correct", it's fine in practice, which is why DAC engineers decided on those filters in the first place. It's more important to have good attenuation beyond that, because that affects the aliases within the audible band.
