Thank you so much for your answers, everyone!
Single 2.5mm locking TRS makes a seamless mod to Balanced pretty difficult.
There's hardly any space to mount alternative connectors either:
Best-case scenario: you find a way to replace the stock jack with a locking 2.5mm TRRS jack.
It doesn't necessarily have to be locking right? And we are talking about 2.5 mm socket, right? I'll have to get a single cord balanced cable with a 2.5 mm TRRS plug. Are there any on the market, or it'll have to be custom made? Sorry if this is a silly question, I don't think I ever saw such cables.
An option, when there is little room, is to make small 'dongles' hanging out of the headphone with 2.5 or 3.5 sockets.
A bit like the Superlux headphones but using sockets instead of plugs.
That seems to be the simplest option given the lack of space in the cups that StaticV3 have pointed out, thank you. I guess this approach may be somewhat more simple than trying to retain a single entry configuration. Is that correct?
It's not like making a hole in the second ear cup should change any effect on the acoustics, right?
Some (most?) headphone amplifiers with balanced outputs can put-out double the voltage from the balanced output. That's 6dB louder.
If your headphones are not loud enough you can find a different regular-unbalanced headphone amp with 6dB or more output (or more) capability than you currently have.
IMO - Balanced headphones are an inconvenient gimmick.
Since I'm planning to use them with a portable source, the pool of potential options is far more restricted than it would be otherwise, I'm afraid. Single ended power output is limited with portable devices, as well as most other facets of performance from what I've seen (though not to any perceptually relevant degree with decent products), though given the sensitivity of these HP's it shouldn't be a real issue even with a ~6-7 dB negative PreAmp value I'll have to set for EQ, and there's a ton of other parameters and features to consider.
But given the low impedance of these HP's, I consider potentially vastly improved crosstalk rejection to be something worth pursuing. I'd much rather have it at around -115 dB rather than around -56 dB I'd get using single ended connection in the absolute best case, even if the purported audibility threshold may be much closer to the former than the latter.
