So far, I've
- braced my CLD cabinets, pushing the first (and only significant) resonance from 260Hz to 455Hz.
- improved driver/case coupling by glueing in T-nuts for the woofer (and tweeter!!)
The difference in clarity and voice/piano realism was immediately apparent with the added bracing. I was really surprised with the improvement I got from doing this with these speakers. I've always increased bracing in speakers I buy, and the improvement this time was easily 4x any of them (and no, there was nothing malfunctioning before). After this massive improvement, when I did the T nuts, I couldn't tell the difference. But they needed to be done anyway because after 5-6 driver reinsertions, it was obvious the MDF wasn't holding as before. Also, oddly, wood screws with thick threads weren't used!
Machine screws!... Such a weird choice - especially at the price point! Honestly, it was probably a sufficient solution for if you only ever replace a blown driver (hopefully never lol) but still...
So yeah... So far, I've done all the easy stuff for these speakers, except for swapping the [sole] unattached fill within the sealed box, to a combination of foam on all outside walls + the correct amount less unattached fill for the same effect (although with less internal reflection). If you consider the bracing improvement as "100%", modding the fill this way might add another 15%.
Since these drivers are exceptionally low distortion (esp 3rd harmonic), I've been thinking...
Instead of making a couple more incremental improvements to the standard included boxes, why not go for gold and make a nearly innert cabinet?! Weight-no-object! Lol
In that vein, I've been thinking... instead of a rubber CLD, how well would a 1/4" thick rubber enclosure contained within a 1.5" thick concrete box with" sand as a buffer in between work? Like 0.5 to 1" sand. And for when the woofer moves outward, the vacuum created within is countered (on the rubber) by a lattice of thick steel wire spaced horizontally and vertically, equidistally 1.5" (apart), and present wherever possible (ie. When it can cross from one side to the other, both sides rubber only - if the driver or crossover is in the way on one or both sides, not there!)
Or is the sand unnecessary, and I should just glue or set the rubber directly on the concrete?
What about other ideas for as innert as possible enclosures? I have a feeling this winter's gonna be colddddd, so I don't mind a more involved project - especially if it'll pay off with listening enjoyment!
Polyfill is very effective at taming these internal midrange resonances as I show, and much easier and less messy.
