I assume the drivers were EQ'ed to the same frequency response prior to making the recording?If you are interested to hear the difference current drive makes, I've found that two-tone tests are quite revealing.
So I recorded samples from a number of drivers and uploaded them here.
For most drivers the difference is very audible in person, but it is also audible in the recorded samples with a good pair of headphones.
I can personally tell the difference (on Airpods Pro) for all samples in the webpage, except for the Purifi.
Yes the tones were at a fixed dBSPL for all drivers across both VD and CD.I assume the drivers were EQ'ed to the same frequency response prior to making the recording?
Yes, FSAF provides an alternative way of auralizing distortion. I believe Michael the creator of FSAF (who is also into current drive) has done something similar to what you describe here and posted the results on the DIYAudio forum.The FSAF measurement provides separated noise and distortion signal that one can listen to. Would be interesting for multitone and also music signals.
FSAF Measurement
I go my heads on a Audeze MM-100 and a Sony MDR-7506. To my surprise, the distortions are most audible on the Sony, with Airpods Pro a close second. The MM-100 is last.If you are interested to hear the difference current drive makes, I've found that two-tone tests are quite revealing.
I don't think there is any reason why band-selective current drive amplifiers are not the default for all active speakers, other than awareness and availability of off-the-shelf solutions.I had given up on the idea that current-driven loudspeaker systems would ever be widely and affordably available on the market,
Yes, after I did this study I have been working a project to just do that for the DIY speakers community. It is a side project and I don't have big business ambitions for it. But if you (or anyone reading) is interested in giving band-selective current drive a try, I'm making small batch that should be ready in sometime in May. You can find the module specs here and a more detailed measurements/discussion of the module here. DM me if interested.but I have hope that if more people like you undertake projects like this, there might still be a possibility.
