Hey everyone,
I’ve been seeing that while most people go with active subs these days, there are still quite a few who stick with
passive subwoofers. I’m really curious to learn from those of you who use them.
A few things I’d love to hear about:
- Why passive? What made you choose a passive sub over an active one? (flexibility with amps/DSP, reliability, DIY, cost, etc.)
- Your setup – Which passive subwoofer(s) are you running, and what amp do you pair them with?
- Use cases – Do you mainly use it for home theater, music, gaming, or a mix?
- Amps – For using dedicated subwoofer amps, which features do you find essential (power output, filters, phase, DSP, auto on/off, trigger, etc.) and which ones are just nice-to-have?
- Good and bad – what’s been great (or frustrating) about today’s subwoofer amps?
I’m not looking for measurements or lab-style analysis (though always welcome on ASR!), but more your personal experiences and what you’ve learned from using passive subs in the real world.
Looking forward to hearing your setups and lessons learned — I feel like this is an area where shared experiences can really help others considering the same path.
Why Passive: with six NAD 2200 amps that can do this: 460 W RMS a channel into 8 ohms, 700+ W RMS a channel into 4 ohms, 800+ W RMS a channel into 2 ohms all @ 40 Hz & can be bridged mono for double the power at either 8 or 4 Ohms, I had to give 2 of them something to do.
My setup: one amp running 4 Ohm stereo for my pair of Dahlquist M-905's (unequilized FR +-2DB from 26 Hz-20 KHz [see HiFi Classsic review if interested]) and one 2200 running 4 Ohm bridged mono for each of 2 subs.
Back in the day, Radio Shack made 2 different floor firing, ported subwoofers (both 12" [one a smaller box tuned for maybe 40 HZ & one larger box tuned for 29 Hz]). Of course, Radio Shack's 12" speakers (even the better one in the larger box) where not that great (& neither was their crossover).
So, around 2008, I bought the best Pioneer 12" automotive competition, dual 4 Ohm voice coil speakers that they made at the time (with a 96 DB @ 1 watt 4 Ohms, 1400 RMS continuous and 2400 watt RMS max), with an FR of 20-80 Hz. And made a circuit that gave me 4 Ohm nominal with the 2 voice coils bridged together. I did this to both subs and ran each sub from it's own bridged mono at 4 Ohm NAD 2200.
My APT Holman PRE OUT 1 goes into a Harison Labs PFMOD (with Highpass set at 70Hz and my Low Pass set at 55Hz:
The Dahlqusts sit on top of the subwoofer box's on a container pad (40FT/80FT container corner pads for the concrete to container interface) 11 inches above the floor, with a backward tilt of 3.5 degrees for optimum coverage of the listening area. Like most free-standing speakers, the M-905 gives its best performance when it is placed at least a foot from the wall and angled slightly inward toward the listener, Quasi-anechoic FFT measurements have shown an overall group-delay variation of about 0.1 millisecond between 4,000 and 20,000 Hz and 0.5 ms between 1,000 and 20.000 Hz, convincing evidence of the attention paid to the phase characteristics of the M-905.
Use cases: mostly stereo but sometimes I configure into quad similar two this manner (ending up being a 4.2 system):
Quadraphonic Synthesis
With two Holman Preamplifiers, you can synthesis and control four output channels from just two input channels.
Apply all your inputs to the first Holman Preamplifier. Use it for all your tone controls, filters and source and tape selections. Leave its Stereo Mode in Stereo.
Connect the first Holman Preamplifier's MAIN 1 output to one power amplifier and your two front speakers.
Connect the first Holman Preamplifier's MAIN 2 output to any line-level input of the second Holman Preamplifier.
Connect the second Holman Preamplifier's MAIN 1 output to the power amplifier for your two rear speakers.
Rotate the second Holman Preamplifier's stereo mode control to L-R, and start by setting it to about unity gain or a bit less, and keep its tone controls flat. The tone and filter settings of the first Holman Preamplifier are fed automatically to the second Holman Preamplifier.
Set balance on the first preamp. Set front-rear balance on the Volume control of the second preamp.
Leave the power switch of the second preamp ON, and plug its power cord into a switched outlet of the first Holman Preamplifier. Now the power is controlled by the first Holman Preamplifier, too.
I use the tone controls & filters to adust the signal to taste (no EQ, DSP, etc.):
Frequency Responses, Bass Control (normal ">--") at 12, 1, 2, 3, 4 and 5 o'clock
Frequency Responses, Treble Control, Apt Holman Preamplifier.
Frequency Response, Normal (left) and 15 Hz filter (right), Apt Holman Preamplifier.
15 Hz filter (only) response.
The low-frequency response is the same with the tone controls either defeated or engaged, for all inputs and all outputs.
The 15 Hz filter is selected with a rear-panel switch.
It's -1/2 dB at 20 Hz, -1 dB at 17.5 Hz, -2 dB at 15 Hz, -3 dB at 14 Hz, - 5 dB at 12 Hz and -10 dB at 10 Hz.
Frequency Response, High Filter (lowest trace), Normal (middle), and Tone Defeated (top), Apt Holman Preamplifier.
The 8 kHz High Filter is only active when the tone controls are engaged. If the tone controls are active but the High Filter isn't selected, then the middle 40 kHz filter is active.
If the tone controls are defeated, then the -3 dB frequency is 150 kHz as seen in the highest curve.
I have a pair of these (bought new & restomodded to newer, better specs (not that they were slouches, by any means but around 46-47 years later, it's likely that one or two things could be deteriated and need renewing or been done slightly better (but for sure, not by much):
Apt Corporation Holman Preamp, designed in 1978 by Tomlison Holman (THX founder and inventor of 5.1 surround).
AMPS- (and everything else in my system) are on a pair of dedicated 20 amp outlets with a USPS between them & the outlet. Tun both USPS's on and it all comes on.
There is no TV in this house (we have not had one since 2007, at my wife's request) & there are no remotes to the stereo system.
Good & Bad: All good, the system does exactly what I want it to do. People who visit ask "How can it sound so great and you only have a couple of speakers & cobbled together subs?" & I answer: "Well, it's simple: you start out by buying great gear that will stand the test of time and add to it as you go along".
