Cubilux Budget 7.1 USB Sound Card Review
Rate this surround DAC/ADC
    Votes: 26 20.6%
    Votes: 52 41.3%
    Votes: 35 27.8%
    Votes: 13 10.3%
comparable to the HifiBerry DAC8X
Sorry OT, but is that a high bar? Only care about AUDIBLE SQ
answer here if you like
It would be very interesting a test of Cubilux CB5. I'm using in Daphile as DAC with the bonus of a decent line ADC. I've tested it on REW loopback with good results but I'll be happy to see a professional test
Cubilux products are unreliable .That has been my experience with their products.
I don't have any other Cubilux products, but I've been using this on my gaming PC as the primary sound output to a receiver with a 5.1 analog input and it's been trouble-free since I bought it a few years ago.
Overgeneralisations are not helpful.
Yes they are not a top tier brand, no one claimed that.
They make a range of cheap and cheerful high utility gear, e.g.
USB to S/PDIF / TOSlink, and vv adapters
pure analog volume knob has a nice ALPS RK27 "Blue Velvet"
What is the use of such a box? It is seemingly dongle sized but for 7.1?
PC motherboards have largely stopped including 5.1 output. If you want decent quality speakers and amps and 5.1 sound on a PC, you need 5.1 analog output. Consumer PCIe sound cards with 5.1/7.1 output aren't really made anymore. There are some consumer USB sound devices with 5.1 outputs but most are expensive or include features you might not need or want (and/or rely on proprietary drivers that may or may not be updated in the future). On my gaming PC I have Cubilux going to an old Onkyo receiver with 5.1 analog inputs and an Energy Take 5 speaker/sub setup for nearfield listening at my desk, and it works well for that task. I also inline a Head Box S2 headphone amp on the left and right main channels since it passes through the audio and then use Nirsoft SoundVolumeCommandLine to change the speaker configuration from stereo to 5.1 via two shortcuts for when I want to switch from headphone to speakers, simply turning off one amp and turning on the other (so no need to plug or unplug anything). It's a handy utility:
https://www.nirsoft.net/utils/sound_volume_command_line.html
(Setting the speaker outputs to stereo is essential for getting proper headphone spatial audio from games like Overwatch which render a Dolby Headphone output from an internal 3D game audio space.)
Some products are no good even for free. Being dirt cheep does not make it good or even a good deal. Worthless to me. I agree with Amirm, spend a few more dollars.
Really? I have just taken a look at a sample of a few motherboards for both AM5 and AM4 socket and found that they all included 7.1 Audio even when it was a cheap motherboard... However they mostly only have 3 analog outputs, so using the 7.1 probably repurposes some of those ports as I know back in the day many motherboards had 6 analog ports, 4 output and 2 input.
The utility looks cool, even if I wouldn't have a use for it. My systems are all paired with headphones and/or 2.1 speakers.
Yes I should have clarified that to get the multichannel audio you now have to run cables to the front the back of the case at the same time, which is just not a great situation IMO. Back in the day they'd put enough jacks on the back for at least 5.1 plus mic, now they skimp and want you to re-use front panel jacks that are normally headphone and mic for other things. For my ASRock X870 Taichi Creator board here's how it works:
ChannelPortFunction
2chLine Out Jack (Rear Panel)Front speaker out
4chPink-Mic (Front Panel)Rear speaker out
5.1chMicrophone Input Jack (Rear Panel)Central/Subwoofer speaker out
7.1chLine-Headphone (Front Panel)Side Speaker out
ChannelPortFunction
Ah okay; this makes sense. So I guess you can buy a header / connector for your tower that will plug into the front panel connectors so that you have all the cables on the back.
I think it makes sense as an option for cost-cutting because very few people have 5.1 especially from onboard audio.
Also this exists:
or
https://www.amazon.com/XRIKUI-Surround-Chipset-Support-Express/dp/B0H7JBX3HV/ <-- C-Media solution
Also this exists:
or
I've seen front panel audio cables/adapters that will put the headphone/mic sockets in a 3.5" bay, but computer cases typically don't have external bays anymore. Bizarrely, I've never seen anyone make a front panel audio to PCI slot bracket cable/adapter. You'll find lots of people suggesting to just "buy a sound card" (I have a small pile of sound cards that I don't use because the drivers aren't updated anymore).
The Creative Sound Blaster Audigy Fx Pro is just a Realtek USB audio chip on a card with a USB host controller chip that bridges it to PCIe, which from an engineering perspective I find to be kind of silly, especially when you then rely on proprietary Creative software on top of it.
I'll look into the C-Media solution, I wasn't aware of it, though using a PCIe sound card would preclude the ability of me to use two GPUs in my PC (which was the whole point of getting the motherboard I have, though my second GPU is currently in my son's PC so I have the space right now).
So that C-Media solution is a CM6212 + CM9881 chipset, which is another USB audio on a PCIe card solution. Better than Creative in some ways since it looks like it would just be plug and play with no special drivers needed at least, but whether it's better than the Cubilux depends on the implementation I imagine. It's frustrating there aren't more product options, internal or external.
An external solution worth mentioning is the Creative Sound Blaster X4 which does have 7.1 outputs in the back:
https://us.creative.com/p/sound-blaster/sound-blaster-x4
Does more than I need (I already have a good headphone amp) and requires extra Creative software I don't necessarily want. Though it does work on game consoles (without the extra software features), so maybe it can work on a PC or Mac without the Creative software? Not sure, and no ASIO driver, which at least the C-Media card says it has.
If you're in the EU and want an alternative to the Cubilux which is not from Startech or a company based in China, there is this:
https://www.terratec.de/details.php?artnr=10715&lang=en
For PCIe on Windows there are plenty of used Sound Blaster Z cards going for cheap (I think I paid like $40 for it 4 years ago). It is CS4398 with their CA0113-4AG Sound Core3D, amirm measured fronts at 102dB SiNAD (2012 consumer card!) and Surround outputs to have 2Vrms output
https://www.audiosciencereview.com/...nd-measurements-of-sound-blaster-z-card.9127/
There is also Max97220 for 2.5Vrms out of Headphone Out (but 22Ohm out). The card is supported by the newer/current "Command" app (drivers are bundled in it), which I personally find ok. Both Optical In and Out are a nice touch imo. The bundled in mic found in the initial Z (removed from Z SE) is not too good, but can be used for Discord. The card probably flies under the radar, because people who buy older cards go for ZxR instead (better DAC +TPA6120 for Headphone Amp +some other features like RCA Input on the second board).
edit: btw. possible uses - you get some old consumer surround speaker set from Logitech or Creative, place it around your Sim Rig, put Subwoofer between your legs for "force feedback", IEMs into another DAC set as source in Discord, helmet on, and drive ;)
I've owned and used many Sound Blasters including the Z, and I've never been very fond of the Creative software. Not that past competitors (such as ASUS) were much better. Which is why I lean so heavily toward solutions that don't need special drivers.
The hardware is there, but somehow they keep messing up the software. Maybe as interest in discrete soundcards die out so do the funding for devs?
