I found bass extension and HF extension poor. It was easy to drive them into distortion. They are ok as far as it goes
but the small cabinet and bass driver size is a big limitation. They are great for limited space and don't suck at all.
But the titanium dome compression horn in the JBL is far better and the giant cabinet, porting, and 15" LF driver satisfy
bass extension. The mid range in the JBL is based on line array driver technique as well. The JBL speaker is in a very different
category with peak SPL listed in the spec sheet as 137db and elsewhere as 130db.
And 124db continuous. Much louder than the bose 301. And it can do it all day long.
JBL says 800 watts continuous, 1600 watts program, and 3200watts peak. Ominous for home use.
The Bose are good from 10 to 150 watts...and without horns for HF and MF just cannot get as loud.
I almost destroyed the 301's with the 1002 amp. I think they are rated at a peak of 150 watts based on how they
folded under high power. It certainly is not a judgement against them...they are for home use, not sound reinforcement
or PA duty.
I just wanted more.
Do the 301 also require an EQ box? What you described sounds exactly like how my 901 sounds without the Bose EQ unit.
