D
Deleted member 48726
Guest
If there are two fans you can wire them in series to get half the revolutions and minimize the noise.
You can also replace them with silent PC cooling fans if the voltage is 12 V.
Or look for an amp which only start the fans at a certain temperature.. Chances are you newer or very rarely see them spin and if you do you play so loud you don't notice it anyway. Yamaha PxxxS models are this way and many others I'm sure.
