Crossover Software for Windows, Linux, macOS.
Cantabile as VST host.
Fine piece of Software
Free version: Cantabile Lite - which does pretty much everything we need her
Also a paid version.
I am not sure that the OP is paying attention to this thread anymore...
The last edit/addition to the first post was about a year ago.
I use Voicemeeter Potato software with Oktodac8pro in 4 ways speakers for a year and get good result
In my PC-DSP-based multichannel multi-SP-driver multi-amplifier fully active audio setup (5-way 10-channel), I use "EKIO" as system-wide DSP center, VB-AUDIO Matrix as system-wide ASIO/VASIO/VAIO routing center, JRiver MC as music player/organizer, and OKTO DAC8PRO 8-Ch DAC.
For the details of my latest system setup, please visit #931 and #1,009 on my project thread.
Wow lots of learning required just to decipher all that, much less grok it all, great stuff!
I see no pricing for Ekio?
Maybe you would be willing to help me understand Ekio, at least how to CLASSIFY it as a DSP tool?
This post gives the "classifying matrix" factors as a starting point:
My first attempt as an example is this one for Acourate https://www.audiosciencereview.com/forum/index.php?threads/asr-acourate-users.47057/post-2540315
if you (or anyone) is familiar with both maybe give some comparison notes?
USD$149. See their webpage. I would classify it as a minimum-phase IIR PC-based filter designer and convolver. Make sure you understand every word and the advantages/disadvantages of each. See this thread to understand the difference between FIR vs. IIR, and minimum-phase vs. linear-phase.
Thanks again, yes getting up to speed on those fundamentals, slowly.
So I thought I'd start just with crossovers, set room compensation EQ aside for now.
I see a lot of the tools discussed in this thread are general-purpose DSP, which PC-based ones do you think I should start with, which
only require the PC for the measurements / design / testing cycle stages
can work with all sources including analog
give flexibility on using say rPi based convolvers, mixed with miniDSP?
I'm fine with Windoze or Linux, but not Mac.
Looking at Echo Audiofire 12, maybe two as I/O interface
so will need an external mic preamp, or Mackie 402-VLZ4 looks like good value.
Reading between the lines, the moment you say "can work with all sources" the answer is "MiniDSP" or one of its hardware alternatives. Going PC-based introduces additional complexity. You have to get the signal into the PC. It's not impossible, but it's inconvenient - you have to reconfigure the audio chain every time you want to switch sources. Trust me, this gets old very quickly.
And "MiniDSP" means IIR, so the answer for "which tool" becomes "REW".
DO NOT BUY two interfaces. Buy ONE interface which has as many channels as you need. Buying two interfaces introduces unnecessary complexity. Yes, you can get it to work, but you will need additional software. And I don't think you need a mic preamp, the Sound on Sound review says it has a built-in mic preamp with 48V phantom power.
I don't understand, at all why "can work with all sources" implies MiniDSP?
The PC I/O interface has 12 channels, high SQ ADC/DAC in & out. Two can be daisy-chained if I need 24, total cost under $350, plus a Firewire card or Thunderbolt adapter.
front-end selector/preamp → DSP convolver → DAC → amps → speakers
I would need to literally save up for years to buy any proprietary DSP hardware box with more than eight channels.
Sorry I was not more clear, only the AudioFire12 is touching the PC.
The Mackie in this case is only being used for its excellent SQ mic preamp, feeding the AudioFire12 via balanced analog.
The AudioFire12 is just a dedicated I/O AD/DA converter and clock
different from what you looked at, has no mic preamp no headphone, no digital I/O other than the FireWire
Because a hardware processor like MiniDSP is the most convenient way to use multiple sources. If you want to switch sources, all you have to do is press a button on your remote. If you run it through a PC, you will have to reconfigure your convolver every time you switch sources. And if you're unlucky, you may have to change the audio routing in your interface. Like I said, it's not impossible. It's just inconvenient and tiresome.
But your proposed solution here:
... would work. Just be careful not to clip the input of your DSP device.
You already know this... but some of their units do indeed have FIR -- limited in taps, however; or completely inaccessible to the user e.g. Dirac proprietary only.
It's somewhat disappointing, but still can be very usable enough for many starting out DIY folks.
No one is stopping one from using another convolver over the basic one already in the miniDSP upstream via PC software to do extra further signal processing which is what I sometimes do when using with jRiver.
For example, in one of the miniDSP config presets I use, I allocate 2048 taps to the sub and 1020 to the midwoofer and another 1020 to the horn of my center channel. What the hell can 2048 taps do for a sub? I use it as a secondary layer of linear phase LPF on top of another min phase LPF -- it slightly reduces the xo phase shift in this case at the expense of an extra 13ms latency.
That's only true of the Dirac equipped MiniDSP units. The ones that don't have Dirac have FIR accessible to the consumer. However, the number of taps is absolutely paltry, and insufficient for any meaningful bass correction, as you noted below.
Have you heard of multirate polyphase filter banks? Essentially, as you note - if you have 2048 taps at 96kHz, the frequency resolution (bin width) is 96000/2048 = 46.9Hz. However, if you are able to divide a signal into sub-bands based on phase delays and change the sampling rate for those bands, you can effectively gain resolution. So for e.g. you were able to halve the sampling rate for bass frequencies, you would also halve the bin width, effectively doubling the resolution. Unfortunately, MiniDSP does not have it. But I heard a rumour that certain AVR's with Audyssey do.
I've become beholden to EKIO. It really is a very intelligently thought out piece of software with good performance. The visual aspects in being able to load FRD's makes dialing in xovers super quick. Only downside is I have to run two audio interfaces, one into the other, but I haven't had any issues with that yet.
Probably heard it from OCA in a video or one of the threads here.
I am not sure if this is similar in concept to what I've done with rePhase here below for example:
Aha, convolver AS preamp! Not of interest currently, I want to keep DSP as a separate piece of the chain, easily removed or swapped out.
Only in some cases, like maybe between film & music for lipsync handling, or between LP vs dancefloor mode.
But switching between CD player and turntable, my FLAC library, internet radio, family phones
weren't you saying swapping out EQ profiles per-input would be unusual?
Ofc the speaker, xover and room compensation EQ parts don't change right?
I said that it makes no sense to apply different EQ profiles for different digital sources. But upon further reflection, I may be wrong. You may want to apply a different set of filters for a DVD player, for instance. DVD implies video, which means latency is a concern - so you may want minphase filters for that. And some people apply a different EQ profile for HT with boosted bass.
