- Thread Starter
- #21
Great thanksHere's a decent overview:
https://www.minidsp.com/applications/digital-room-correction/dirac-live-vs-rew
Picked up a NOS Alesis 3632 very cheap, just for the Limiter functionality to protect the LS50s when testing/measuring. Supposed to be a much better quality design and implementation than the ol' 3630Kef's should stay in the equation at the whole process and as you value them enough you should know that it wouldn't be safe.
Since these will be co-located with the LS50s I'd say 300Hz or higher to keep the LS50 mids (waveguides) as stationary as possible. Assuming the chosen drivers are up for it.Assuming the basstands are good SQ right up into midrange, do you think there would be any advantage to going past say, 300Hz for the LS50 HPF ?
If subs and mains are tight together I would start low, 120-140Hz and go upwards while measuring.Picked up a NOS Alesis 3632 very cheap, just for the Limiter functionality to protect the LS50s when testing/measuring. Supposed to be a much better quality design and implementation than the ol' 3630
Looking at using Wiim Amp Ultra PEQ for all frequency filtering on the LS50s, emulating crossover since I need to keep the LPF output to the basstands in stereo.
I can't use the Amp Ultra crossover function for LPF to my "bass modules" since they are stereo, acting as stands for the main treble/mid pair.
But I think I can use the PEQ function to get there with a PAIR of WAUs. Just say for example I want a xover at 400Hz, WAU#1 on treble/mid set to 400Hz-infinity, then on WAU#2 custom bandpass filters set for 70-400Hz,
is that do-able ?
I assume I would want a "brick wall" 24 dB/octave slope but plan to test. Also maybe an actual overlap, all to be tested / tweaked using REW or Roomfit or (suggestiins welcomed)
Google says:
> Configure the...
If 120Hz were high enough, I'm guessing a true mirror crossover using the ICBM would be the better tool.
How much higher should I be considering / testing ?Since these will be co-located with the LS50s I'd say 300Hz or higher to keep the LS50 mids (waveguides) as stationary as possible. Assuming the chosen drivers are up for it.
Could you explain why, and/or link to a HowTo?If subs and mains are tight together I would start low, 120-140Hz and go upwards while measuring.
Thing is that going higher you have to have anechoic data.
Do you mean location? The stereo basstands are literally speaker stands for the LS50s, main thread in the OP.If subs and mains are tight together
is that do-able ?
Google says:
> Configure the...
That last is not fixed, the real point of the project is to enable / determine highest possible "safe" SPL of this model, including in a mobile / outdoor context.You can simply test them out without subs at these crossovers and see if they sound strained at all at your loudest listening levels
The limiting factor should be the lowest frequency coming from the LS50 and the maximum SPL it can produce there.the real point of the project is to enable / determine highest possible "safe" SPL of this model,
Is that what gives it the wide dispersion?You should not cross the LS50 higher than about 200-300 as it's only omnidirectional below that range.
Actually distortion at 200 hz is at 60 db while signal is at 96 db. Thus distortion 36 db below signal which at 200 hz is 1.77%. So as long as you high pass the LS 50's with something 12 db octave or greater above 150 hz, the THD should be much improved, provided you have two low distortion subs placed in close proximity to the LS 50's.The limiting factor should be the lowest frequency coming from the LS50 and the maximum SPL it can produce there.
If you check the review, the distortion goes over 100% at 96dB even at 200hz so you can't really go beyond that regardless of what kind of bass stand you add.
The distortion situation does not improve until after it crosses to the tweeter, so that's pretty much your limit any way you slice it.
You can reduce distortion below 200hz or so for cleaner bass, but this speaker has limits even in the midrange so you won't be getting PA levels from it either way.
The filter is a high pass on the LS 50 Metas, so it will attenuate below the crossover frequency only. The Low pass on the sub will attenuate their output above the crossover point, and since there will be a great deal of natural roll off above 150 hz on any sub anyway, it won't be necessary to do more than 24 db/octave at most. Probably a L-R with 24 db octave on both legs will take care of everything as long as the subs are close (like 24 inches) from the mains.Thanks much!
Above 150 hz, yes, but I'm asking at what higher point should I not bother testing?
"12 dB per octave" is about slope not xover point correct? Way too gentle compared to what I was planning
Based on a 150 Hz cutoff frequency and a 12 dB/octave slope, there will still be a lot of attenuation into 600Hz ranges.
I was thinking lots steeper would be necessary, more brick wall ish.
Even so, I do believe the biggest issue with the Metas is not their harmonic distortion in the bass, but rather their high levels of IMD carrying all the way into the midrange (1000 hz and up) when played at higher levels
Get a speaker with lower IMD, or play the Metas in a smaller room at lower levels is the only thing I can think of. Since the IMD is the result of the woofer-tweeter interacting since they are mounted on the same surface, the only thing that ameliorates it is for the woofer to have have lower excursion which is somewhat achieved by crossing over at higher frequencies, but the issue is inherent in coaxial drivers.Aha thanks for furthering my learning!
Just a reminder, not talking about "subs" wrt these stereo basstands, yes they are colocated with the LS60s, since they are acting as their stands
If I do decide I need (true mono) sub(s) the basstands will be high passed at the sub's starting point, likely 70-80Hz
The Outlaw ICBM I plan to use for that crossover only does Butterworth 12 dB/octave slope for the HPF, but for the LPF gives the option of going to 36 dB/octave.
Is there anything that can be done to ameliorate that, other than lowering the volume?
OK thanks.Get a speaker with lower IMD, or play the Metas in a smaller room at lower levels is the only thing I can think of. Since the IMD is the result of the woofer-tweeter interacting since they are mounted on the same surface, the only thing that ameliorates it is for the woofer to have have lower excursion which is somewhat achieved by crossing over at higher frequencies, but the issue is inherent in coaxial drivers.
