I did come across these, but some comments mentioned them not fitting correctly/securely?There are a number of bluetooth earhook options out there. All the Truthears I own use 2-pin .78mm connectors, as does the Crinear Daybreak. I couldn't confirm the connector on the Crinear Reference, but I'd be shocked if they went with a different connector. Something like this should work:
TRN BT20S PRO | Worldwide Shipping | TRN-AUDIO
TRN BT20S PRO is a wireless Bluetooth 5.0 modules. Qualcomm QCC3020 chipset. AptX/AAC/SBC HD codecs. 72 hours continuous playback. Learn more!trn-audio.com
Another important point with the Crinacle reference => not EQ ^^Just got a pair and have been testing.
Best set of IEMs ive ever used. Period. Agree on the HD600 comparison, but with the bass that you always wished was there.
Star of the show ironically is the bass, the definition and 'purr' on them is unreal without losing any sense of balance with the mids or treble. The treble is exactly what i'd want - perfectly smooth.
The best bit - i have absolutely no desire to do any EQ - it "just works" - out of the box.
Don't think unless some huge new technology comes along in the future i'll ever need to buy another pair of IEMs. Endgame for me.
Congrats Crin!
Having done quite a bit of Googling, it doesn't seem like there are any good wireless earhook options that fit these or the Truthears?
While 20$ iem sound decent, the difference is quite big. I guess you dont use 50$ speakers which you just eq.An IEM for $350?
Pass - I'll buy 15 or 20 perfectly good ones instead.
Nope. I never bother with EQ for speakers. Not even with my 'phones TBH. I have thousands of albums, and I could end up EQing for too many of them, but I'd rather listen to the music than fiddle about.While 20$ iem sound decent, the difference is quite big. I guess you dont use 50$ speakers which you just eq.
Speakers and IEMs are not the same, IEMs are minimal phase devices and as long as there is no excessive distortion frequency response is the most important metric for how they sound, so even a low cost set can be equalized to a given target curve, no matter the price or tech.While 20$ iem sound decent, the difference is quite big. I guess you dont use 50$ speakers which you just eq.
for example KBEAR 07, Tangzu Sancai or something from SpinfitI'm trying to find an aftermarket eartip that matches the specs of the 'Standard' version packaged with the Reference. Their stock standard, medium tip offers me the best balance of sound, isolation and comfort. Suggestions very much appreciated. Thanks!
Thanks. I've ordered the KBear 07 set and will welcome other suggestions.for example KBEAR 07, Tangzu Sincai or something from Spinfit
"The CrinEar Reference has an official nozzle diameter of 6.0 mm at the retaining lip, with the main shaft measuring approximately 5.8 mm. The nozzle length is roughly 4.0 mm."
"If you are planning to buy or swap eartips, these specifications fall on the larger side, generally requiring ear tips with a core diameter of 5.5 mm to 6.0 mm for a secure fi
These sound really good. They’re non-fatiguing, everything sounds correct, and nothing feels overwhelming.
I’m also lucky that this shell shape fits my ears really well.
There’s a bit more sub-bass than I expected, but I must admit I like that.
Andrew gives the CrinEar Reference a 7.5/10, the highest spot on his current ranking list. He concludes that it is one of the best IEMs on the market for those who want a versatile, high-fidelity tool that reveals the true character of their music [00:19:18].
It isn’t broken. A 10 means ideal in every respect. I actually like that they’re using the full scale, instead of the usual reviewer inflation where everything gets an 8–10.I feel like their scoring system is broken if they’re declaring something to be the best and giving it 75%
Yes, like they often mention in their reviews they use an absolute scale and not the typical audiophile journalism superlatives rating.It isn’t broken. A 10 means ideal in every respect. I actually like that they’re using the full scale, instead of the usual reviewer inflation where everything gets an 8–10.
And you can see the scores are improving over time — though a cynic might say that makes sense, given that their sponsor sells the newer stuff.
