Protocol Max dongle released, but apparently sold out?
CrinEar Protocol Max Portable DAC-Amplifier
The Protocol Max marks CrinEar’s bold entry into the source gear market, bringing our philosophy of acoustic precision to digital-to-analog conversion and amplification. With up to 600 mW of clean power on tap from its balanced output, the Protocol Max effortlessly drives everything from...hangout.audio
Thanks for the post! I've sent out a unit to Amir so we may see some measurements on ASR, but in the meantime here's some data from our lab:
SINAD on single-ended/balanced (600Ω load):
116dB on SE, 117dB on BAL
THD+N vs Power output on Balanced, 32Ω and 300Ω loads:
500mW (32Ω) and 54mW (300Ω) maximum power output
4Vrms max
THD+N vs Power output on Single-ended, 32Ω and 300Ω loads:
125mW (32Ω) and 13.5mW (300Ω) maximum power output
2Vrms max
Multitone Distortion at 0dBFS, -15dBFS, -30dBFS, -45dBFS:
Mainly to show that the Cirrus' DRE-induced IMD "hump" has been corrected in this DAC.
SMPTE ratios are kept comfortably under -100dB above -25dBFS.
FFT 44.1kHz:
On the default filter: Fast roll-ff, low-latency (Fast-LL)
Output Impedance:
<0.3Ω (SE), <0.6Ω (BAL)
And of course, the user guide on how you can upload your PEQ profiles to the Protocol Max can be found here, alongside more specifications should one be curious.116dB on SE, 117dB on BAL
4Vrms max
2Vrms max
FFT 44.1kHz:
Output Impedance:
