Looking at the CanJam ads from #1, it seems only the Daybreak have flush nozzle, while both Meta and Reference will have lips?
All 500 sold out in 40 minutes and Crinacle talked about maybe producing another 499 units at most. He said "Project Series" are experimental models for testing the water.Hopefully it is popular and the limited run will sell all the Meta iems. This will hopefully prompt a second wave of production which will not be limited.
good...at least it's not just lip service
you have to put your hopes on Hi-Fri(unless someone breaks one open and publishes what drivers it uses, spoiling the surprise)
There seems to be a bit of hype around the (lack of knowledge of )drivers . Imagine when it turns out to be 1dd and 2 BASpoiler: after everyone receives their units and evaluate them, reviewers review them, and the hype settles down, I bet that then Crin is coming with a new video explaining what crazy driver configuration Project Meta uses that he did not want to disclose before to avoid prejudices. And customers were 999 blind test guinea pigs paying to evaluate his theory. How crazy would that be?
I was in luck to pick up a pair of Meta's. I don't really have a need for it though, so if they're not amazing to me, one of y'all can take over my pair![]()
Wonder if they go in order of order time or random . Not sure if it's 500 including review samples . If it is none of us are getting 001We can all compare serial numbers
Perhaps @crinacle can elaborate .
Dang it . Should have rolled the dice and waited for batch 2 for 666, 777, 888.Review samples are separate from customer units and are all unserialised.
Units are sent out at random within batches (i.e. you won't get 001 if you're in the 501-999 batch). Good luck!
