Well their own "online marketeers" are claiming the app version performs worse than the hardware version because of... some reason. So whatever stored on the phone may not be the same as what the hardware does.
I don't think so, because only the bundle with the trio aurvana se is offered for 69€, the sxfi amp alone still costs 89€.
Curious pricing...I don't think so, because only the bundle with the trio aurvana se is offered for 69€, the sxfi amp alone still costs 89€.
Is that GEQ which you use by dragging the frequency response curve or can you use PEQ? i couldn’t see any documentation.I am not sure it was mentioned, but the sxfi amp has 10 band EQ built in that is independent of the sxfi mode.
Hi David, it is 10 band GEQ:Is that GEQ which you use by dragging the frequency response curve or can you use PEQ? i couldn’t see any documentation.
