hi there,
It is for quite some time that I am reading this forum, but I figured it's time to sign up now ...
I have been on-and-off into hfi since the mid 1980ies ... I do know my way (somewhat) around hifi now, as I have made many mistakes along the way ;-)
Having said that I have a Q:
for reasons that I don't want to dive into too deep, ( I can get A130ies fairly cheap, but the bigger stages like the A170 are way more expensive here), I have this crazy idea:
Running 2 sets of JBL Stage A130 in parallel, iow at the same time.
I poked around a bit and here's the plan:
at this stage the whole thing is more of a mental exercise (I'm not running out and buying 2 pairs tomorrow ;o)
so I'd definitely be interested in some educated guesses/thoughts/experiences for this kind of (possible) experiment.
So what do you think
best thanks for your time ;-)
cheers Al
- I did demo the A130 and liked them quite a lot .... I cannot demo the A170 and had to buy them "blind" - which together with the way higher price makes me uneasy
- so a could stack 2 pairs of Stage A130 - run in parallel at the same time to get a bit more ooomph from them (fairly big room)
- the A170 is a A130 with extra 5" woofer (and obv. more interior volume)
- my amp (virtue audio two.2) can be used down to impedances of 2 ohms ... so that fact that the impedance would drop from 6 to 3 ohms by running them in parallel should not be a problem
- I plan to run them stacked vertically - I understand that running them side-by-side is a no-no (for soundstage and phase reasons)
- putting the tweeter ends of the speakers together (so the top speaker would stand on its head) - to get the higher frequencies radiating from (nearly) the same spot and minimize any undesired resonances (suckouts or increases)
- I think I might get away by using the same speakers (as opposed to 2 different types)
- I figure if it's not working, I still can sell the 2nd pair of 130ies used at minimal loss - so not too much of a (financial) risk if it sounds like $h!t
cheers Al
