wpatters1229
- Joined
- May 11, 2025
- Messages
- 4
- Likes
- 0
This is making me nuts. I have a projection TV that works fine, and connected to it is an Apple 4K TV device. From that device, I transmit Bluetooth 16-bit sound to a Pioneer receiver. When I scroll through icons on the Apple TV home screen, each time, there is a crackling noise coming out of the right channel. It can also be heard in my earphones that receive Bluetooth from the receiver via a third-party transmitter connected to the right and left channels of the Zone B output.
I have swapped the Apple TV with another one, and nothing has changed.
I thought it might be a problem with the receiver, but I hear it in the right channel only of the headphones, and if the headphones are off, I can also hear it in my surround sound right rear speaker, and I am assuming the right front speaker. I can not tell about the front speaker since it is background noise.
Here is the crazy thing. If there is a movement or change from one thing or another on the Screen, the crackling noise happens, but then about 2 seconds later it stops. If I am watching a show, it is in the background all the time until I hit pause, and then it stops after 2 seconds.
I believe it has something to do with the Bluetooth transmission to the receiver, but not sure. The Apple that is providing the Bluetooth transmission is only about 12 ft from the receiver.
Does anyone have ANY ideas on what would be causing this? I can ignore it most of the time, but my OCD is making it hard to do.
