Could use some advice...Newbie here
Tama2112
Hello all I hope that everyone is doing well. Hifi newbie here and a little confused on some things...I plan on hooking my laptop to an external dac then dac to preamp. Question #1...I'm going to use a usb-a to usb- or-c to usb input on dac correct? Then I will go to preamp from rca outputs on dac? What do the other end of those rca cables go into on my preamp? Will I be able to achieve hi rez this way using Tidal or Qobuz? That is my ultimate goal is to stream hi rez, also if I stream Tidal over wifi with my android phone this will bring hi rez too?? Thank you.
Hi
This sounds about right. What comes after the preamp, headphones or speakers? If the latter you need either powered speakers or a power amp between the preamp and speakers. One additional consideration, sometimes, instead of rca (unbalanced) cables people use xlr (balanced) cables for the connection between DAC and preamp to help address any possible ground loop issues you might have.
What preamp? Usually CD in with the connections any other line level
Should work just not Phono if your preamp has it.
The DAC built into your soundcard may be perfectly adequate. A headphone-output can double as a line-output. If you don't hear noise (hum, hiss or whine in the background) it's probably better than human hearing. The other important specs (noise and distortion) are almost always better than human hearing. (Once I had a soundcard that made noise when the hard drive was accessed.)
You may not need a preamp either. A preamp is mostly a "control center" with multiple inputs, a volume control, tone controls, etc. Sometimes a volume control knob, or remote control is nice if your DAC doesn't have an one. Tone controls are nice too. It's easier to make a quick tone control adjustment than to fuss-around with digital EQ.
A traditional preamp has multiple line-inputs, sometimes labeled "CD", "tape" or "aux, maybe even "DAC". (A "phono" input is different.) A modern preamp may have digital inputs (and therefore a built-in DAC) but HDMI and S/PDIF (for DVD & Blu-Ray players) is more common than USB.
You didn't say where you're going from there... A power amp or active-powered speakers?
I'm not really an expert on streaming. I'm not sure if you can high-resolution lossless if you use Bluetooth. Even with wired USB connections, if everything isn't configured perfectly, high-resolution can get down-sampled to 48kHz or 44.1kHz. (You'll still get the bit-depth of your DAC, usually 24-bits.) But regular resolution "CD quality" or even lossy compression can be excellent and you might have to listen very carefully to hear a difference, if you can hear a difference at all. Sometimes the high-res version is mastered differently and then it can sound different... Hopefully better, but you can't always be sure...
Better (or different) speakers (or headphones) will make a bigger difference than switching back-and-forth between high resolution and standard resolution, or even good quality MP3! If you can get high-resolution that's great! But speakers (and room acoustics) are more important.
I have a rotel power amp that is hooked to my preamp which is an NAD C379, the rotel is powering a pair of Polk bookshelf speakers. Sorry for the lack of info.
You can stream Hires audio from your phone or computer directly to the C379 using BluOS - no external DAC and no wired connection to the NAD required.
If you don't like BluOS, then you can connect a WiiM Mini to the C379 via Optical and stream Hires Tidal/Qobuz to it instead.
If you don't have the expansion cards in the NAD you could use usb > optical to the C379. Looks like you can use Bluetooth aptX HD to stream to the C379 as well.
