Currently I've been using Logitech Bluetooth adapter but I noticed that it is giving me some static,buzzing sound through tweeters so Im trying to get something of a higher quality.
Logitech adapter is connected to - Numark M6 USB - Driverack PA2 - Amps - Speakers
I could probably use rca to xlr cable and bypass Numark mixer and tap into driverack directly if signal strong enough.
I use it for spotify and youtube audio via android s22 ultra. I have wifi/ethernet port in the room.
I thought about WiiM Pro or audioengine b1 / bludento blt-hd or some mixers with build in bluetooth but would like to get some advice before I make a purchase.
Based on the reading I've done wifi streamer should give better sound quality over Bluetooth is that correct?
