Cost of XLR outputs in DACs
DuxServit
Just wondering about why some DACs don’t have XLR outputs:
(a) Does XLR outputs increase the complexity of the DAC design?
(b) Does it increase the BOM costs? If so, by what percentage?
NTomokawa
Correct me if I'm wrong: XLR output level standard is 4 volts while RCA is 2 volts.
A simple inductor-based boost circuit will measurably degrade the output performance. That is without taking into account the fact that XLR is supposed to be balanced (3-pin vs. 2-pin) so you have a more complex signal path implementation.
Also bigger connectors = bigger board = bigger casing = higher cost.
DuxServit
DuxServit
Right. But by how much?
Or is it simply a marketing strategy (call the XLR version a "new product", the big brother of the RCA-only, then charge extra 50% to 70% more).
KSTR
Berlin, Germany
BOM cost of a basic XLR output derived from an output buffer is, well, the XLR socket and two (2) equal break-out resistors, 100Ohms typically. One goes to the buffer, the other to ground. This fulfills the balanced connection requirement of that there shall be impedance symmetry. Signal symmetry (wrt ground) is NOT required to exploit the virtues of a balanced connection, but impedance symmetry is.
This kind of XLR output of course has the same signal level of the corresponding unbalanced output (derived from the buffer output with a single break-out resistor, again 100Ohms typically).
In most consumer gear, the balanced out is often made with a unity-gain inverter tapped off from the unbalanced output (the actual buffer output, that is) and hence offers signal symmetry and twice the total signal level. Sometimes, the level of the XLR out is made the same as the RCA output, at increased complexity.
In yet other cases, when the signal path of the device is fully balanced internally, we already have the signal-symmetric balanced output and then the unbalanced output is made from a simple differential amplifier of unity-gain (hence same signal level) or gain on 0.5x (half the level, to avoid headroom issues -- clipping) of that gain stage. Again, the break-out resistors are used, they provide isolation of capacitive loads (long cables) so that the op-amps used won't oscillate.
Killingbeans
Bjerringbro, Denmark.
I think it's mostly a supply and demand thing. Most users wants to use RCA cables.
DuxServit
DuxServit
Looking at the DACs that Amir has measured, there is a price threshold of say $200, above which XLR output is required.
LTig
Europe
My Tascam outputs about 12 Vrms differential at full volume.
Tascam is not consumer gear. My RME DAC outputs +19dBu (6.9 Vrms) unbalanced and +24 dBu (12.3Vrms) balanced maximumat 0dBFS, can be reduced to +13 dBu (3.5 Vrms) and +4 dBu (1.2 Vrms).
Monstieur
Does reducing the volume by 2 dB reduce the voltage from +16 dBu to +14 dBu?
sergeauckland
Suffolk UK
Yes.
By the way, the EBU defines 0dBFS = +18dBu, as that provides 12dB headroom above the normal European peak operating level of +6dBu. The UK normally operates at +8dBu, so we have only 10dB headroom. Most US practice is, I understand, 0dBFS =+24dBu as that provides 20dB headroom on 0VU (+4dBu) necessary when using VU meters rather than PPMs.
Aren't standards wonderful........
S
Monstieur
My DAC (Steinberg UR44C) says it has a +16 dBu line-out. This clips my amp (Monolith THX Desktop) input - it has an "OVER" indicator on the LCD. I'm assuming reducing the DAC volume to -2 dB results in +14 dBu (< 4 V RMS) on line-out, which the amp can handle without clipping.
sergeauckland
Suffolk UK
Yes, that's right. +16dBu is just on the threshold of what the Monolith can handle on its XLR inputs, so +14dBu would be better.
S.
