eddantes
- Joined
- May 15, 2020
- Messages
- 962
- Likes
- 2,108
Hello all,
There have been a few threads asking about cost of DIY vs buying 2nd hand. As always my recomendation is - if you want HiFi on the cheap, but the best bang for the buck commercial offerings 2nd hand - it is a no contest. DIY is for the joy of doing it yourself, costs be damned.
So I wanted to present here an estimate for a project I am considering - a two way with a big woofer to try to cover as much of the FR as possible while keeping directivity from being completely out of whack. This is me being my maximum frugal - using the cheapest components I can find (eg. electrolytic caps), buying on sale (woofers) and second hand (tweeters) - and this is what the budget entails.
As you can see - hardly a bargain. Now let's see what can be bought for CAD $700 -$900 second hand. Not linking here, as I don't want to be promoting, but presented here as a table - if you know where to look you can confirm my findings. I will try to list only examples of speakers we know to be good performers from measurements (so - no exotica or crap).
Obviously this is in Canada and the above is not considered in terms of bargain / rip off - just what is readily availlable.
Of those I found. Polk R200 is likely the closest in concept. Here are some specs of it: (F3
And here is what I have conceptualized:
Theoretically - Mine will go deeper but have less linearity and a worse DI. But going deeper is the whole point with these.
So there you have it folks - DIY - for shits n giggles; 2nd hand for bang for the buck.
