Corvette or 911
ex audiophile
I've been debating the purchase of an STR preamp or miniDSP SHD and it reminded me of all the old Car and Driver comparisons between the 911 and Corvette. Expensive, elegant and sophisticated or blue collar rough around the edges but less expensive.
So, I have a nice quiet amp (AHB2) and want to put together a nice 2.2 setup that is streaming only (Node2i source) and includes room correction capability. I have experience with the Anthem STR preamp and it's been superb, likely transparent based on Audioholics testing, and has a ton of features, many of which I don't need given a streaming only system. It does have a slick interface with a lot of preferences that can be set to make life easier (startup volume, max volume, turn off delay, ARC settings, etc). ARC Genesis has been excellent at sub integration for me and it's super easy to use. Retail is $4300.
In the other corner is the miniDSP SHD, much less expensive at $1200 give or take, but lacks phono inputs, HT bypass (I think) and likely has a more cumbersome UI with fewer preference settings. I have no experience with miniDSP stuff so that could be wrong. However, it has a high performance DAC and DIRAC with apparently countless settings and options for tweaking the signal. Probably a better choice for someone who likes to really get into the weeds with the EQ settings.
My question for you all is which do you think would be the better choice for a streaming 2.2 setup WITHOUT REGARD to the cost difference? My hypothesis is that the ultimate result with regards to SQ would be the same and would depend more on the speakers and subs. The STR would be smoother and easier but the SHD would provide more options for adjusting the FR curve. Comments much appreciated.
JeffS7444
Room correction is the low-hanging fruit of the audio world, where real sonic gains can be had at reasonable cost.
As for 911 vs Corvette, beats me, I've never driven either.
TonyJZX
I'd go with the minidsp preamp first... its only $1,299... it runs dirac which is the undisputed industry leader... you're better off trying that one before you go for anything 'better'...
as far as 'preamps' go, i'd be considering the minidsp as the 'minimum' as far as connections which is normal for a preamp
you be probably needing something ontop to fit many peoples' setups
it does tend to have enough digital inputs... sort of... 1 opt, 1 coax, 1 aes/ebu
it only has one xlr in and one rca in
it does have heaps of analog and digital outs though
so in my setup i'd probably need an analog input preamp ontop
but this minidsp is at least 'workable' for me
droid2000
Corvette has closed the gap in performance against 911's. A 911 will be more reliable, but the rear engine design is a serious flaw that requires extraordinary engineering to fix. A much cheaper Cayman with a 911 engine outperforms a 911. Porche relies on unthinking loyal 911 consumers to maintain the brand... much like Macintosh amps and Harley Davidsons.
restorer-john
Buy American, get a Corvette.
Wouldn't been seen dead in a car made by VAG.
buz
This.
I am very much the 911 target audience and would never buy one for those reasons.
pma
Prague
The car choice is secondary here, just as a comparison. He asks for advice in audio choice.
TonyJZX
btw. if you're going to get that last of the combustion engine cars before we're all forced to go electric then you may as well go with a format that has always been best for most enthusiasts and that's a large naturally aspirated V8 with a 6 spd manual driving the rear wheels.
That's it.
So a C6/7 Corvette... or a 911 GT3 or even a Carrera 2... i can forgive the twin turbo flat six or the RR engine location... because...,
I'm not interested in the auto experience.
fpitas
Northern Virginia, USA
Once upon a time not so long ago, Corvettes were kind of embarrassing. When people showed up at the road race track, we all expected to be entertained by the marginal old man suspension and wheezy engine. No more.
fpitas
Really;) no wells fargo with a lot of horses?
They corner very, very well. People frequently bring them to autocrosses and also do well.
symphara
The miniDSP will probably be more customizable in terms of EQ but the loss of HT bypass would rule it out for me, personally. I seem to always end up integrating some HT setup with the audio setup and this flexibility is crucial.
The 911 is a much nicer car to live with compared to the Vette. Better visibility all around, physically smaller, nicer interior, can easily be a daily driver. The Corvette does look like a high-tech supercar though, inside and out, I'll grant that.
BR52
Germany
Great they corner now well. Pls forgive I'm a Porsche fan
fpitas
fpitas
Astoneroad
a Cave in the desert
With speed limits... and limited hearing range... we pay beyond what we're capable of actually experiencing in the real world. What we spend to burn in the Bonfire of the Vanities... is an odd human behavior... IMHO.
AdamG
Moderator
Reality
Mini DSP and use the remaining $3100 to get a couple nice subs if you don’t have subs yet. If you have the subs already. Upgraded Speakers is where you will reap the largest improvements in sound in the Audio Chain.
