Corrected my post...
I actually do understand that electrons jump from atom to atom in a wire and don't flow independently like cars down a freeway. And I also understand that current is flow and voltage is potential and their combined "power" is used to overcome resistance and related factors that "resist" or "impede" the flow of electrons.Wire goes to speaker and then comes back. So the total length/resistance is twice as much or 12 feet.
You stopped before the interesting bits! https://en.wikipedia.org/wiki/Hydraulic_analogyImpedance is for all circuits and includes resistance as a special case when the signal is DC. Music is AC.
I'm sure there is a wiki that would help with these concepts, and likely a Dummies Guide too.
A simple analogy of electricity is to a garden hose...
voltage ~ water pressure
current ~ water flow or flow rate
resistance ~ clamping down on the hose
I remember the ten gallon water pipes fed with a garden hose in the 70's. The only "coil" you needed to worry about concerned the lungs.All these gauges remind me of my vape days..
Vaping relies on usually hand wound coils with a moistened wick filled with "e-liquid" when vaporized turns into the vaper desired. The device sends a current through a the coil, and depending on the resistance, and such things like gauge, usually speaking, the more mass a coil has, the more vapor you can produce. Now a cloud comp, is a vaping competition where people do smoke tricks or try to produce the biggest amount of vapor. And you will usually see in such competitions, guys working on their coils. Hence the meme of trying to make the biggest coil in hopes of not shorting the device potentially or other factors while producing the biggest "cloud" of vapor.
However, I don't really "grok" the differences between resistance, impedance, inductance, and other factors that affect electron flow
Don't worry about electron flow. Impedance (Z) includes resistance (R) and reactance (X): Z = R + jX. The j is for the imaginary part of the impedance and is equal to square root of (-1). Look up complex numbers (mathematicians use "i" instead if "j"; EE's use "j" so it does not conflict with AC current which is also "i"). The reactance can be capacitive, inductive, or a mix of both.
I'll stick with basic ideal components so we can say:
So over frequency, a pure resistor stays at R ohms, but a capacitor's impedance (reactance) goes down as frequency goes up, and an inductor's impedance goes up as frequency goes up. That means a capacitor passes more current, or has less voltage drop across it, as frequency increases. An inductor will have higher voltage drop across it or less current through it as frequency goes up.
- A pure resistor just has resistance R in ohms.
- Capacitor impedance varies inversely with frequency (f) so XC = 1/(jfC), magnitude in ohms.
- Inductor impedance varies directly with frequency so XL = jfL, magnitude in ohms.
There are probably lots better descriptions on the net, with videos and pictures, but hopefully that gives you the basic idea.
- If you put a capacitor in series with the signal, it will block low frequencies and pass high frequencies.
- If you put an inductor in series with the signal, it will pass low frequencies and block high frequencies.
HTH - Don
I know you know this Don:
XC = 1/2.pi.f.C
XL = 2.pi.f.L
Oh good grief. Two stupid mistakes in as many days. I think my insane work hours and lack of sleep are catching up to me. I am used to writing frequency in radians per second (w) and w = 2*pi*f so when I made the last-second change to Hz (because most people are used to that) simply left off the 2*pi factor. Duh.
As for leaving the "j" in, well, I got nothing...
Thanks, corrected... - Don
Don uses directional cables to keep the resistance low.You forgot to multiply by 2 Don since it is a roundtrip.
My dad is an electrical engineer, high voltage transmission lines, substations, nuclear power plants and used to design and build his own tube amps but he can’t explain this stuff to save his life, you guys aren’t much better
what’s funny to me about hifi is it’s something that should be basic science but there’s a human factor that carries emotion and feeling and the science and engineering must become more poetic in nature.
anyway I’m just waiting on my coffee.
Your dad studied EE for years with all its maths and physics to understand this stuff and you expect it to be delivered to you, at your level of understanding, in an easy grab-bite.
I get the feeling he knows he would be wasting his time.
that was a bit harsh and somewhat off base... I‘M fully aware I’m not going to understand it nor am I going to spend the time to master it but it is fascinating and enjoyable to me to read about it.
As a side note he didn’t go to school for it, started out making wire in the warehouse but he does write all over other engineers drawings who did go to school for it. He’s one of those people who just gets it while everyone else spends years trying to figure it out.
In my line of work most people can do the work but don’t grasp it, that’s true on this forum as well! What category do you fall into?
