Not looking for snake oil but I am looking for the correct speaker wire for my application. I have some very difficult to drive speakers that have significant impedance dips at certain frequencies. It’s been suggested that I should power them with a 250 watt 4 ohm amp but I’m using a 100 watt 8 ohm amp with a moderate 4 ohm rating. I’m currently using off the shelf 16 gauge cables about 6’ long but I want to get some 12 gauge cables. Am I wrong to assume the 16 gauge wire is putting extra stress on the amp? Also I found Maze Audio cables, 6’ 12 gauge that are visually appealing and look well constructed for $80 a pair. Anyone have experience with that company or another suggestion in the sub $100 range and aesthetics are important second to build quality. I’m aware that I can get some 12 gauge cable for $40-$50 but if I’m spending the money let’s just a little bit more for something appealing?
