My cables definitely follow the correct wiring standards. I've noticed before that in their unbalanced cables (CFU series with RCA or TS plugs), they still use 3 conductor wires (red, blue + shield) instead of a simpler coaxial cable (signal + shield), but I don't have any issues with that. They're wired up correctly for unbalanced applications: red and blue soldered together for the signal and shielding for the GND.I wouldn't swear without testing them first:
What we see here is that the two red+blue (should be twisted) conductors are used for (+) and the shield is split in two for (-) and shield.
It does not make sense at any configuration.
About connectors, XLR are nice/basic but the RCA side of the cheap REAN far-east varation of Neurtik can fall apart if used to a nice tight female connector, the pin can start rotating and eventually short with the ground.
There are far better options out there.
Is yours an adapter cable maybe? 2x XLR to mini jack "aux" for example?
