Cordial CFU and Ceon Review (Cables) and more
NTTY
Reviewer
Switzerland
Hello Everyone, this is a quick review and detailed measurements of the Cordial CFU and Ceon cables, and a little more.
A friend of mine asked me what are the cables I use for my (analog) measurements. And I went Cordial cables simply because my preferred local shop is selling them. This question, together with the recent review of Amir about some Kimber Cables, made me want to go a bit deeper, and perform some measurements, of course ;)
The above photo shows all cables I included for this quick review, to make a bit more interesting.
There are the two Cordial cables (those with the TS end) that I regularly use:
  • Cordial CFU labeled as a "pro audio low noise cable" (the black one).
  • Cordial Ceon which is "DJ" cable, meaning flashy for the ease of identification, and very flexible. It is my default cable.
The other cables are no-name ones that I got with devices I bought here and there. They include:
  • Standard RCA cable (1m) with golden connectors (the one with the white ends)
  • Very basic RCA cable (3m) probably very old too
  • An AliExpress cable said to resemble an old McIntosh interconnect, included as a gift by the seller when I bought a genuine McIntosh amplifier
Last and not least to complement this list, I travelled to France recently, went to a Shopping Center (Leclerc), and bought the cheapest of their RCA cable, 1.5m for 2.78€. This is a photo of this one with the Cordial Ceon:
Measurements
I followed the review of the Kimber Cables from Amir, and so I went only for few measurements, including the standard "SINAD" dashboard, bandwidth, jitter and square.
My setup is very simple, the computer (REW Software) drives a Topping D50III converter (used as the generator) and the RCA output of the Topping is measured by my usual Cosmos combo Scaler + ADCiso Grade 0. All of these items run on batteries.
So it is: REW Software (generator) -> Topping D50II (DAC) -> RCA Cable Under Test -> Cosmos combo (ADC) -> REW (FFT analyzis)
I set the D50III to output 2Vrms.
Let's start by measuring with my usual Cordial Ceon, as it is the one I prefer using. The below is a 1kHz sine @0dBFS:
As you can see, the calculated SINAD (opposite of THD+N in the above dashboard) is identical to what Amir measured in his review of the Topping D50III (121.4dB), the only difference is that I get the same results from the Left or Right channel of the Topping (0.1dB difference only).
For this measurements, I set the Topping to 48kHz sampling rate, FFT length was 32k and I used 4 averages, and that is to replicate the setup of Amir's AudioPrecision (3 averages instead of 4, though, as I can't select 3).
The unweighted SNR calculated in presence of that Full Scale (0dBFS) test tone is a crazy low 122.3dBr. This is state of the art and if a cable would make a difference, that level of precision would allow us to easily spot that.
And as a matter of facts, at that level of precision, almost anything makes a difference. For instance I got better results when the battery pack powering the ADC was at least 50cm away from it, while I usually just put it below...
Let's run the same measurement switching to the Cordial CFU:
The THD+N remains -121.4dB (meaning a SINAD of 121.4dB). The measurement is therefore nearly the same, maybe that 50Hz little spike went down from -145dbr to below what can be measured with that FFT length.
During my measurements and attempts to reach the lowest level of noise, I noticed that the Ceon was more likely to pick up noise than the CFU, but never to the point of reaching an audible level, only something I don't want in the context of high precision measurements.
Let's continue with the basic 1m RCA cable that has golden connectors:
Nice, even a little better than the two Cordial cables. This is 0.1dB better of SINAD, not relevant and likely due to the shorter length of the cable.
It is anyways good to see that a standard RCA does the job perfectly well, and does not get in the way of the highly resolved Topping DAC.
Next is the other very basic 3m RCA cable from probably 20+ years ago:
Hey, very nice too, same as the Cordial. That probably means I lose 0.1dB of SINAD with 3m cable instead of 1m.
Let's continue with the pseudo McIntosh cable from Ali:
This is the same result as the Cordial Ceon. Note that this cable is stiff and heavy, everything but practical to use.
Last is the cheap one I got from France:
Finally we get to see something!
This one is picking up some mains (50Hz) and harmonics from I don't know where since all devices run on batteries. There was nothing I could do to reduce this and I tried a lot of potential solutions (disconnecting all other surrounding devices, using an additional USB isolator, placing the cable differently, etc...).
Anyways, the SINAD degrades a little to a still extremely good 120.7dB which would keep the DAC in the "Excellent" category of Amir's chart. At least we have one cable that shows a little difference, yet of no importance...
As @amirm did with the Kimber cable test, let's continue with the bandwidth up to 200kHz. The below is an overlay of all cables:
Despite my usual zoom, they are the same. I did zoom much more and saw a very little 0.01dB difference between the "best" and "worst" cables at 200kHz.
Same in time domain, with a 20kHz square as Amir did with the Kimber test (but bandwidth is limited to 384kHz in my case). Results are identical between the best and the worst cable. For that reason, I show only one measurement, since all are exactly the same:
The ringing is due to the filter of the Topping (I'm not using a super resolved Generator as Amir with the AP) and a bandwidth limited to 384kHz (my maximum) instead of 500kHz.
Let me add a quick standard Jitter Test between the worst and best cable (FFT extended to 512k and 32 averages to visually lower the random noise):
I zoomed to better see potential side bands. The two traces overlay nearly perfectly, i.e. no difference.
Conclusion
Nothing new under the sun, I know.
Cables would make a difference if one had a massive issue, being incorrectly built, or of an extremely high length, placed next to a switching power, ...
In the end, buy what pleases you, for the convenience, the look, the price, ... and enjoy your music.
Have a nice WE!
Cool to see this data. I still use some of the cheap RCA cables that came with hardware decades ago. The only problem cables I bought were from monoprice and it wasn't an issue with distortion. It was connectors that were too loose to stay attached and cables that just started falling apart. I switched to Amazon Basics and all those cables have worked great with zero issues.
Hello Florent,
On French forums the topic of cables is very often forbidden because it generates endless discussions that can be summed up by "man hears what no measurement can measure!!...". Personally, I think a properly built cable is sufficient without going into the craziness you can read about the "magical" properties of certain cables.
In modern line level analog interconnect systems (low output impedance >> high input impedance) of reasonable construction and length),
the only differences will be in interference suppression and reduced Common Impedance Coupling Noise current.
Both of these involve the associated equipment and the situation environment.
I know some people are hopelessly running down this rabbit hole of cables and there is nothing that can be said, done or otherwise to show them the truth but this review/bench test is needed nevertheless.
I will attempt to add few words of logic and reason to this cause:
Noticed that there are no cable companies that discloses the technical specificities of how their cables would sound different using legitimate science to explain (science that can be cross referenced and checked in science text books)?
How and what would make a cable give you a "wider soundstage" or "fuller bass" or "more organic"? If you can't explain it, then how did you make it?
Yes, some will cite "skin affect" or "timing domain" coherency, but if you look deeper, that is not applicable to audio cables, akin to citing "escape velocity" when talking about a car.
Measurements
Conclusion
Have a nice WE!
Now we still need tests for specially burned-in cables (from the service provider), cryogenically treated cables, OCC OFC solidcore N6 cables, genuine single-crystal copper cables, a cable braided by virgins under a full moon, and...
i'm guilty of liking nice audio cables. can't help it. these green cordials looks great. can't even recall the brand i'm having, but a nice soft sleeve + made in germany, or preferably made in japan imprint is giving a certain satisfaction when connecting :)
Hello Florent,
I'm French and I haven't frequented French forums for a while... French audiophiles are incredibly ignorant and completely uninterested in science, to the point that they're all convinced the human ear is more precise than an Apx555.
Measurements are designed to prevent people from being ripped off by all those crooks selling cables at exorbitant prices...
That’s interesting. I’ve always thought of the French as inclined towards rational, scientific comparisons…
In fact the English words rational, scientific and comparisons each have French origins. C’est la vie!
I am currently down a strange rabbit-hole and from where I stand: Could this be leakage current? If my gathered knowledge is correct, leakage current is the enemy number one in floating systems (no earth grounds). If I am correct, you should be able to verify this by connection one (and only one) of the DC neutrals to earth ground and it will go away.
Oh, my god, thank you for finally proving how big a difference cables make in the sound of your system. Great job! I got $5k in my pocket for a 1 meter RCA cable.
Wait? What, that didn’t happen? My bad!
Never mind.
Hello Florent,
Well, in general, our whole human existence has a solid belief system, which some questions. So you really can’t totally blame audiophiles if they want to believe also.
Never mind.
Hey, I was kind of shocked that the cheapest cable actually measured worse, even if the difference was beyond human hearing.
I once isolated airborne 50Hz to a router wall-wart (pre-SMPS era) in the same room, and conducted 50Hz to a fan. Your 50Hz is like 50dB lower than mine so the culprit can be way further.
Leakage current, leakage voltage, same same chicken and egg. Electromagnetic waves induce movement of charge. If charge can flow with low impedance you get more current, if charge is impeded the charges pile up and you get more voltage. Electric guitar and vinyl find a balance of R, V and I.
Usually a completely floated equipment will have the whole equipment, well, completely float together and follow the common-mode voltage of the EM wave (airborne waves are common-mode voltage by definition technicality). Connecting one point to ground makes that point, welp, ground, while other parts may remain more coupled to the EM wave, resulting in a differential voltage across your device. That's how antenna works basically.
When we say "leakage current is the enemy number one in floating systems" it is with respect to the context: The normal consumer expects things they touch to... be of a voltage that does not kill people. When a device is floated, if done perfectly the common-mode voltage becomes undefined. But more realistically there will always be some amount of coupling to somewhere. When I touch a piece of metal (previously otherwise electrically floated), the metal's voltage becomes the same as my voltage. This is the case for things running on batteries. A lot of "floating systems" with problems are referring to appliances where the secondary side is ungrounded (A safety requirement commonplace nowadays, regardless of class I or class II). But when we say ungrounded tho, it is still slightly-coupled to the nearest low-impedance voltage source. That source would be AC mains voltage, with coupling usually through the transformer. (On a class I appliance, the resistor between secondary and primary side / earth is supposed to fight that). Going back to the point above regarding current vs voltage, if the charge induced by this electromagnetic coupling is not discharged, then voltage piles up, usually to slightly below half AC voltage.
In that context specifically (not the "everything running on battery and thrown into an EMI test chamber" context), the solution, be it people doing it knowingly or unknowingly, is to get everything to the same common-mode voltage, which is usually easiest achieved by connecting everything with a big fat connection to ground. But even this is not 100%, because some audio equipment have a power or signal reference point that is not direct ground. In such cases improving the load's coupling to earth instead of to the source can have an opposite effect (= more noisy). In some cases, like my computer with a wall-wart power supply connecting to a TV connecting to an amp, it can even sound like something is going to explode depending on the earthing arrangement.
