sfogg
- Joined
- May 11, 2025
- Messages
- 213
- Likes
- 177
I understand that. I was pointing out that the plugin doesn't do any sort of ambiance extraction or surround sound. It is generating reverb and adding it to the music, not using what is already within the recording. Your quote above confirms that. I referenced the Lexicon file as it explains the difference between ambiance generation and ambiance extraction. If you are trying to take a stereo source and play it back in surround sound you need ambiance extraction, also called surround processing and lately called upmixing.Thank you for the Lexicon information but, I was talking about the VST:
OrilRiver VST plugin review: Reddit community's perspective
Based on discussions and feedback on Reddit, OrilRiver is a highly regarded free reverb VST plugin among music producers and audio engineers.
Here's a summary:
The plugin also has a wide number of presets for two channel I haven't tried, taken a recording processed with OriRiver and then running in through 5.1 or 7.1 multichannel yet.
- Excellent Sound Quality (especially for a free plugin): Many users praise its sound, often comparing it favorably to commercial options. It's described as capable of producing natural-sounding ambiance for various instruments and vocals, as well as lush and expansive soundscapes.
- Intuitive and User-Friendly: Its layout and controls are generally considered easy to understand and use, making it suitable even for less experienced users.
- Separate sliders for Dry, Early Reflections (ER), Reverb, and Wet signals.
- 12 ER presets and 5 reverb tail variations.
- Basic controls like pre-delay, width, and decay time.
- Additional parameters such as room size, diffusion, damping (intensity and cutoff), and modulation (speed and depth).
- A three-band EQ for fine-tuning the reverb's tonal characteristics.
However, from just fooling around with the plugin, I have gotten some amazing results from two channel.
Example of a 2 channel stereo mix (meters on left) being surround processed into 18 channels (meters on right) with nothing at all being added that isn't already in the recording.
