HiFi is an attempt to recreate an acoustic event. The means of creating an auditory illusion of this is traditionally a two-channel system.
The scientific approach in this forum is — for good reason — mainly concerned with reliable and correct reproduction of recordings.
However, stereo might not be the scientifically optimal way to achieve the desired illusion. It goes a long way, but we have learned some things since the introduction of surround sound and Atmos systems.
Do we even know what the best way to record and reproduce sound is? I suppose binaural recording and using headphones might be the simplest way, though it comes with some practical limitations.
This was a long introduction to get to the point.
Working with Jamo in the 90s, I learned about the advantages of using an additional center channel, especially for people sitting slightly off-center.
In a normal stereo setup, a listener sitting off-center will have the stereo balance skewed because the sound from the nearest loudspeaker will be louder and arrive earlier, both of which contribute to the nearest loudspeaker becoming dominant. As a result, even a mono signal will produce a phantom center image that appears off-center.
This problem can be mitigated by using a center channel for the mono part of the recording.
My question now is: Could it be a good idea — and even possible — to convert recorded stereo (L/R) signals into three signals (L/C/R)? And how would you even do that? I am mainly thinking about processing digital signals in real time.
My initial idea was to send L+R to the center, L−R to the left, and R−L to the right, but I suspect there might be issues with phase and levels.
What is your take on this?
