sceptical1
- Joined
- Mar 10, 2025
- Messages
- 181
- Likes
- 164
Considering a modern speaker that conforms to the constant/controlled directivity advocated by Olive/Harmon I find that sparse absorption between the speakers (rockwool 3"-24 x15, 2 pieces) and a considerable distance of > 3ft. to the sidewalls is what is needed to take advantage of those proposed improvements claimed for an on/off axis FR similarity and accuracy.
Interaction relative to the proximity between speakers allow for a mixture of the left and right channels that is far from predictable. Absorbing those inside reflections results in a far more stable and consistently coherent soundstage not to mention, more of a cardiode response by reducing the effects of the room.
My LP is a 10.5 ft. triangle with the speakers pointed a foot inside on axis.
Reflections outside of the stereo pair that add to a sense of ambience (if those sidewall reflections are not absorbed, as cautioned against by the experts) are further enhanced by highly reflective sidewall material such as glass or plastic. I get perfectly coherent phantom images at 30° beyond the speaker, if you like that kind of thing. My problem is that those instrument sounds are independent of the overall soundstage image...at the wrong level for volume and position...a distraction from homogenous, carefree listening. There is a Pink Floyd song and some by Madonna often mentioned that impresses some listeners, I mean those type of distractions.
Is this a common theme for others, can sparse absorption in the right position make a huge improvement, is directivity room dependent, are you easily duped by surround sounding effects of stereo yet ignore every word Toole says about the superiority of multichannel reproduction?
Thanks for commenting.
