Consonance CD 120 Balanced Review (CD Player)
Rate this CD Player
  • Terrible (*)
    Votes: 1 1.8%
  • Mediocre (**)
    Votes: 12 21.1%
  • Good (***)
    Votes: 31 54.4%
  • Excellent (****)
    Votes: 13 22.8%
NTTY
Reviewer
Switzerland
Hello Everyone,
This is a review and detailed measurements of the Consonance CD 120 Balanced CD Player and Transport.
Consonance CD 120 - Presentation
Allow me to drop the "balanced" in its name, as it seems there never was an unbalanced version only.
This is one was loaned to me by a friend who wanted to know its real performances. He also told me that this CD Player was considered as a "refence" by a French magazine who used it for a couple of years as the basis for their other reviews. I can't verify that info.
The Consonance is from China and I see it was sold at around 1000€ in 2004. It is no longer available. This CD Player uses a Philips drive (VAM1202) and a Cirrus Logic DAC (CS4396) that is capable of a 100dB SINAD when fed with 24bits data. The CD 120 looks luxurious and the impressive weight of 10kg (22lbs) confirms that feeling,
The back of this player offers a little more than the essential since we get balanced and unbalanced outputs:
Only one SPDIF output though.
Let's have a quick look inside:
Power supply and servo control on the right, conversion and digital output on the left. This one is far from empty!
User experience
The drive is pleasantly fast and reactive, I like it. The remote control is missing with that one and the front button can't be used to FFW/REW which slowed me down in my measurements (too bad for me).
I'm always missing a headphones out, especially with relatively high price devices.
It is gapless playback, proper CD player that is, together with de-emphasis that is applied. Before measuring this CD Player, I enjoyed listening to it with my friend and I did not spot any issues, as nearly always.
Consonance CD 120 - Measurements (Analog outputs)
All measurements performed with an E1DA Cosmos ADCiso (grade 0), and the Cosmos Scaler (100kohms from unbalanced input) for analog outputs, and a Motu UltraLite Mk5 for digital.
I am now consistent with my specific measurements for CD Players, as I described them in the post “More than we hear”, and as I reported them for the SMSL PL-200 review. I used the commercial version of my Audio Technical CD for all measurements. Over time, this will help comparing the devices I reviewed.
The Consonance CD 120 outputs a higher than usual 2.350Vrms from left channel (unbalanced), and 2.355Vrms from right channel (0.01dB more). This is a good 1.1dBu more than from the standard 2Vrms, which is enough to make this one "sound better" than most of the competitors, because it plays louder... Channel imbalance is very good.
I god the exact same results from balanced outputs (same output voltage).
Phase is dead flat, and both outputs respect absolute polarity.
I measured the near same performances from RCA and XLR outputs (XLR are a bit better), BUT one channel (right) suffered high harmonic distortion when close to or at full scale. Not to the point of me hearing anything wrong, but quite significant in my measurements. I guess this is because of some aging components (?), so I'll review this CD Player based on the left channel only, although I'll show you the issue for the sake of completeness.
As usual, let's start with my standard 999.91Hz sine @0dBFS (without dither) from the Test CD (XLR out):
We are very close to the max resolution of the CD Player and the Cirrus DAC stays below -100dB THD indeed. The below is the RCA output, by the way:
It is the same to the exception of side bands very close to the fundamental (no consequences). Note the best in class SNR measured by the software, in presence of that full scale test tone. This means the DAC is high resolution (in case we doubted it).
A now, like I promised, this is the right channel (RCA):
You see high odd harmonics of the fundamental (3kHz, 5kHz, ...). The sum reaches -73dB but as I mentioned before, it was not enough for me to spot an issue when I listened to this player, if someone wants to talk audibility... As a matter of facts, this issue happens only at, or close to full scale. Let me show you that.
At -16dBFS, the two channels are nearly identical (999.91Hz @-16dBFS, no dither):
In this case the 3rd harmonic is almost the same between left and right channels (-93dBr vs -100dBr). I guess this explains why we did not hear anything.
Now, back to my regular measurements, 999.91Hz @-6dBFS, no dither, left channel:
This is a very good result, for the CDA.
Let's have a look a potential Power Supply leakages, the below is a 20Hz to 1kHz zoom with a punishing 512k FFT length to reveal issues:
I overlaid the left channel from XLR and RCA outputs. As I already mentioned, the only difference between the two is the side bands around the fundamental at -115dBr here. This is not an issue at all, by the way.
This is a very silent CD player, not PS related spikes can be seen.
Next is the bandwidth:
This is within -0.1dB, very good I'll say. You can appreciate the near perfect channel match.
Let's have a look at the behavior of the oversampling filter beyond 20kHz:
The filter is relatively sharp and fully active at 24kHz with a max attenuation of -100dB (good). The noise created by the delta-sigma modulator shows itself not before 50kHz or so, that is good too. Aliases of the dual AES tones are well attenuated (-100dB). This is better than the NAD C540 I just reviewed.
Let's have a look at the multitone test that a lot of you like very much:
Nailed.
Oh yes, the jitter test:
Nailed too, I'd like to always see the same.
Started with the Teac VRDS-20 review, and on your request + support to get it done (more here), I'm adding now an "intersample-overs" test which intends to identify the behavior of the digital filtering and DAC when it come to process near clipping signals. Because of the oversampling, there might be interpolated data that go above 0dBFS and would saturate (clip) the DAC and therefore the output. And this effect shows through distorsion (THD+N measurement up to 96kHz):
Intersample-overs tests
Bandwidth of the THD+N measurements is 20Hz - 96kHz
5512.5 Hz sine,
Peak = +0.69dBFS
7350 Hz sine,
Peak = +1.25dBFS
11025 Hz sine,
Peak = +3.0dBFS
Teac VRDS-20-30.7dB-26.6dB-17.6dB
Yamaha CD-1-84.6dB-84.9dB-78.1dB
Denon DCD-900NE-34.2dB-27.1dB-19.1dB
Denon DCD-SA1-33.6dB-27.6dB-18.3dB
Onkyo C-733-88.3dB-40.4dB-21.2dB
Denon DCD-3560-30.2dB-24.7dB-17.4dB
Myryad Z210-70.6dB (noise dominated)-71.1dB (noise dominated)-29.4dB (H3 dominated)
Sony CDP-X333ES-30.5dB-24.8dB-16.3dB
BARCO-EMT 982-32.7dB-24.5dB-16.3dB
TASCAM CD-200-73.5dB-36.3dB-19.7dB
Sony CDP-597-30.4dB-24.7dB-16.5dB
SMSL PL100-53.1dB-31dB-19.1dB
OPPO BDP-95-39dB-28.8dB-19.2dB
OPPO BDP-95 (vol -2dB)-95dB-97.5dB-32.7dB
SMSL PL200-94.8dB-97dB-39.5dB
SMSL PL200 (vol -1dB)-94.8dB-97dB-58.7dB
Orpheus Zero-88.7dB-87.3dB-56.8dB
Azur 640C V2-89.8dB-91dB-64.5dB
NAD C540-34.1dB-26.3dB-20.4dB
Consonance CD120B-84.3dB-39.6dB-20.9dB
The Consonance has only 1dB headroom for intersample overs as so many other CD Players. I’d prefer more since so many CD Masters are recorded too hot.
Let's continue with the good old 3DC measurement that Stereophile was often using as a proof of low noise DAC. It is from an undithered 997Hz sine at -90.31dBFS. With 16bits, the signal should appear (on a scope) as the 3DC levels of the smallest symmetrical sign magnitude digital signal:
This is a very good trace not only showing perfect linearity but also minimum low level noise.
Other measurements (not shown):
  • IMD AES-17 MD (41Hz & 7993Hz 4:1): -111.3dB
  • IMD SMPTE (60Hz & 17kHz 1:4) : -94dB
  • IMD TDFD Bass (41Hz & 89Hz 1:1) : -101.8dB
  • Dynamic Range : 98.7dB (without dither @-60dBFS)
  • Crosstalk: 100Hz (below -140dBr), 1kHz (-138dBr), 10kHz (-132dBr)
  • Pitch Error (GPSDO corrected) : 19'999.90Hz (19'997Hz requested) ie -5ppm
  • Gapless playback : Yes
Sorry I have only a limited set of IMD measurements as I kept them for the right channel and forgot to record the left one... They are good.
The Dynamic range and crosstalk are best in class.
Pitch error is a very low -5ppm.
Last and not least, I like to run a THD vs Frequency sweep at -12dBFS as it shows how the conversion has evolved over time. I am currently using the beta version of REW and I discovered that this sweep gives better and more reliable results than before. I overlayed the results with the excellent Azur 640C V2:
Same, meaning best in class performance here too for the Consonance.
As I did with the Sony CDP-597, I add a "max DAC resolution" measurement test. It is performed from a 999.91Hz sine @-12dBFS with shape dither (from Audacity). I restrict the THD+N span to 20Hz - 6kHz in REW not to account for the noise of the shape dither beyond 6kHz. I take the calculated ENOB and simply add 2bits to it (due to the -12dB attenuation, as 1bits=6dB). The potential maximum, when calculated from the digital WAV file, is 18.7bits under this test. A "transparent" DAC should achieve 18.7bits, ie 100% in this test.
Here are the results compared to others:
CD Player model or DACCalculated ENOB (999.91Hz sine @-12dBFS with shape dither, THD+N span = 20Hz - 6kHz)Percentage of max resolution achieved (higher is better)
SMSL PL-20018.7bits100%
OPPO BDP-9518.7bits100%
SMSL PS-200 (from CD player)18.6bits99.47%
Denon DCD-900NE18.5bits98.93%
Orpheus Zero18.4bits98.40%
Azur 640C V218.3bits97.86%
Consonance CD 12018.2bits97.33%
Onkyo C-73318bits96.26%
SMSL PL15018bits96.26%
SMSL PL10017.9bits95.72%
Sony CDP-59717.5bits93.58%
Onkyo DX-735517.3bits92.51%
Denon DCD-356017.2bits91.98%
Yamaha CD-S30316.8bits89.84%
Revox B-226S16.8bits89.94%
Accuphase DP-7016.6bits88.77%
NAD C54016.6bits88.77%
Sony CDP-337ESD16.6bits88.77%
Teac VRDS-25x16.5bits88.24%
Marantz CD-7314.9bits79.68%
Hey, not bad at all for a 20 years old CD Player! Anything better than 18bits in this test must be considered high-res DAC.
On demand from the community, I now add a "de-emphasis test" to verify that this flag is detected and the compliance with the expected de-emphasis curve.
At 11kHz, we should see 8dB difference, so we have a small deviation of 0.5dB here.
Consonance CD 120 - Testing the drive
What would be good measurements if the drive would not properly read a slightly scratched CD, or one that was created at the limits of the norm? The below tests reply to these questions.
Here are the results:
Test typeTechnical testResults
Variation of linear cutting velocityFrom 1.20m/s to 1.40m/sPass
Variation of track pitchFrom 1.5µm to 1.7µmPass
Combined variations of track pitch and velocityFrom 1.20m/s & 1.5µm to 1.40m/s & 1.7µmPass
HF detection (asymmetry pitch/flat ratio)Variation from 2% to 18%Pass
Dropouts resistanceFrom 0.05mm (0.038ms) to 4mm (3.080ms)0.75mm
Combined dropouts and smallest pitchFrom 1.5µm & 1mm to 1.5µm & 2.4mmFail
Successive dropoutsFrom 2x0.1mm to 2x3mm0.5mm
These are not so good compared to so many others, but the drive of this one was replaced, maybe some further adjustments would be required.
Consonance CD 120 - Digital output
Ok, so we get a decent CD player here. And to expect better from a modern DAC, we need a perfect digital output. Let's check that.
This is my standard 999.91Hz @0dBFS (no dither):
Perfect.
Next is the 3DC test:
Nailed, as expected.
My ultimate proof of "perfect" digital output is when I reuse the intersample overs test at 5512.50Hz, with a phase shift of 67.5°, like I did for the TASCAM CD-200 review. This signal generates an overshoot of +0.69dB. And so, if the signal would be modified before being sent (by an ASRC for instance), it would show either a reduction of amplitude or we'd see some sort of saturation/increase of noise/distorsion. So here we go with the Consonance via the Coax out:
No distortion and the dashboard shows +0.69dBFS as expected. No ASRC on the digital path here. SNR is only 95.6dB because there is rectangle dither in this test file (consuming half a bit of resolution).
So we get a "perfect" transport in case you're not happy with the internal DAC.
Conclusion
Besides the limited resistance to scratched CDs, the performances of this CD player are quite decent.
I assume the issue with the right channel is unique to this one, and I must say it only impacted the highest level test tones.
And by the way, I thought it'd be interesting to share with you that this issue remained completely hidden to the ears of my friend, his wife :cool: and me.
I hope you enjoyed this review!
Flo
This is just measuring for the sake of measuring. And that goes for all these cd players articles lately.
Rip your CDs to a hard-drive, recycle CD player after that. Done.
No measuring needed.
Well there might be 2-3 readers here who are in love with that "I'll go up now->browse my CD collection->press eject button on my CD player->put in another CD disk->grab a seat->repeat" cycle but they are most likely to eventually get the medication they need.
Yikes, why the hate? If you don't like reviews of classic equipment, fine, then don't read them, and certainly don't dis them. They take time and effort to create just like anything else here.
I'd like to personally thank @NTTY for keeping a review stream flowing while Amir was busy with AXPONA.
silly
I regularly listen to cds. I even bought a cd player recently based on one @NTTY's reviews. So I find these reviews useful. Maybe I’m just one of the three dudes interested, though.
The only medication I need is a nice ale after I press play on my cd player.
Another great review of a beautiful CD player, thanks to @NTTY!
I thought I was familiar with all the higher-end CD and SACD players, but I can't recall the name or even what it looks like. I've never even seen it used.
That's only because you didn't go into the kitchen. From there, you would have noticed the difference like night and day ;).
CD player...lol
You’re welcome. And I guess this is you’re way to wish speedy recovery to @amirm
And seriously, 5 posts to share you’re non interest in a disrespectful way while it is as easy as ignoring me?
Alternatively, you can make the effort to review the latest whatever gear pleases you. @amirm would happily promote your review. That requires a little more efforts than your posts though.
To ignored members list.
Excellent review and for a brand I had never heard of before. I learn so much from this site.
Thinking that everybody have the same perspective as you is not being much open minded, but ok.
You already disregarded people not thinking you’re way. I guess I know what to do.
CD player...lol
That's your opinion, but it's not everyone's.
Personally, I find these tests very interesting and am happy and very grateful that @NTTY, @Scytales, @ReDFoX, @Thomas_A, @2TheLighthouse, etc., go to all this trouble.
These tests and the user experiences that are posted help many people with their purchasing decisions, because the devices are not all the same, just as their measurements and functionality are not.
For years now, CDs and vinyl records have seen a steady and continuing increase in sales.
Global music sales consist of streaming, approximately 76%, and physical media such as CDs and vinyl, approximately 22%. The rest is made up of paid downloads and other methods.
Therefore, CDs and vinyl records are definitely not a niche market.
Prices for used CD and SACD players are also rising year after year.
In addition, more and more new CD and SACD players are being released every year. In the last two years alone, over 20!!! new, high-quality desktop CD players have been released, and more are on the way.
This is no longer a niche market.
So, as I said, it might be uninteresting to you, but it is to many others. And these are the hard figures from worldwide sales, and that's all that matters to the market.
Thanks for another detailed review! I’d never heard of Consonance before.
Do you ever come across Rotel players? I had an RCD991 back in the late 90s which I absolutely loved. I wonder if these hold up now and measure well?
HB
@NTTY Did you try a standard Marantz / Phillips remote? I have found a lot of these Chinese players using the VAM mech also use RC5 codes for the remote.
Thanks for all the reviews - ignore the ignorant comments, it's actually great to see how these older players measure compared to the measurements made back in the day.
HB
They are on my list of desired items to review but I don’t see them often. Some were using the HDCD DAC from BurrBrown (PCM1732), and I found it in a Harman Kardon CD Player that I will review soon. But I’ll continue to chase them.
