This is EXACTLY in line with my case, but my LS50s are the OG model before the Meta line (similar power handling I believe). My goal is to get "maximum safe" SPL out of them.
These speakers require an amp with both high Damping factor AND high Current to overcome voltage drop, due to the fact that their "nominal" impedance in reality can drop down to 4Ω or even a bit lower.
All that means well over 100W continuous and HIGHER for peaks is better than lower, as you state headroom is A Good Thing.
Many say Class D is better than "chip amps" but measurement says, not always especially when price is important.
My benchmark for "ideal" current / power delivery for LS50 is GFA-555, Parasound HCA line, "1200 II", 2205a for multi-channel, HCA-800ii bridged.
I recently came across Proton D1200 and NAD 2200 "Power Tracker" tech too but unobtainium.
The Purify, nCore, Hypex and Benchmark lines obviously are great, IMO Schiit Vidar look good and I agree Topping B200 would be great - all just out of my budget. 8-(
Also, critically, I'm looking for **DC-powered amps** that approach those levels but that don't cost the earth.
The other factor mentioned above is also critical, and that is Bass Management. High Pass filtering the LS50 signal will allow higher "safe SPL" with less demand for the peak power requirements.
As mentioned, having all that headroom cannot hurt, so long as you know you will keep output turned down to safe levels. Start playing with DSPs though, beware!
Also the LS50 family are weak SPL at the low end anyway. I am looking at adding co-located stereo "basstand" MBM modules to "reinforce" the 40-200Hz range (or even higher?), and maybe not even need any BRuTeS (Bone Rattling fUll-size TruE Sub) for the bottom end. Maybe a smallish singleton for room modes.
Nearly everyone here says to go multi-channel DSP to handle the crossovers, but pricey, and since that is often included in car amps for hardly any extra cost and I need DC powered amps anyway...
I also have an old school Outlaw ICBM-1 to work with.
Finally, my household includes partying teens, with stupid friends over often when I'm not home, so I am hoping to find **technical** solutions to protect my LS50s
Thinking maybe an SPL-monitor triggering a strobe light at level A, power shutdown at level B (not joking but lack of skillz, need good guidance).
I also found a Alesis 3632 cheap on eBay to try as a peak limiter, but not sure how well that will work, might affect SQ?
OP, if any of this resonates you can go down my posting history rabbit hole for more detail, feel free to post tangents here since your topic title has been answered
To everyone else, I'd appreciate any feedback on all the above - will move the convo to other / new threads if desired.
