Saturn94
- Joined
- Feb 17, 2023
- Messages
- 115
- Likes
- 115
- Thread Starter
- #61
Thanks for the clarification and explanation.Did you get your Closed X EQ from Oratory, from the following link?
I only say that because the pic I included a few posts earlier was of an HD560s EQ, so you don't want to be using that (albeit I did make that ultra clear in my earlier post, but just wanted to double check with you here).index/list_of_presets - oratory1990
r/oratory1990: Mostly covering topics like headphones, in-ear headphones, acoustics, electroacoustics, acoustic tuning, headphone design …www.reddit.com
The BW column stands for Bandwidth - it's just another way of describing the same thing as Q-Factor, which is basically just describing how narrow or wide an EQ filter is; the wider the filter then the more frequencies it will effect either side of it's centre point - ie a wide filter will look wide & flat on a frequency response graph in comparison to a narrow filter which will look sharp, narrow & pointy. The lower the Q-Factor then the wider the filter. The higher the Bandwidth (BW) then the wider the filter. They're both just describing the shape of the filter in terms of it's width of frequency effect, and you'll use Q-Factor or BW dependant on what your EQ software uses. Most EQ software uses Q-Factor, so you'd just ignore the BW column and instead input the Q-Factor settings into your EQ program. So of course you don't use both at the same time, you use one or the other dependant on what your EQ software is setup to use.
Yes, I understood the pic you posted from Oratory was just an example and not for the Closed X. I found the Closed X listed in that same Oratory link posted earlier and used it. I greatly appreciate you making sure I wasn’t using the wrong settings.
