Bernard23
- Joined
- Nov 25, 2020
- Messages
- 824
- Likes
- 637
Owned the JDS dac/amp for a while, and no desire to change it. Was feeding it from a PC Desktop + Roon, but decided to replace that with a Wiim streamer. Didn't do my homework properly, and bought a used Pro, but I now have the issue of mating either a toslink or coax digital out into a USB-B in on the JDS. There are devices that can convert from optical to USB, but the only ones I can find are limited to 16 bit conversion.
Other than re-instating Roon which I am loathe to do, seems the only option is to replace the JDS with a dac with more inputs.
