Connecting a laptop to a Yamaha a-s501 amplifier via an external DAC
Mihail76.
Hello everyone! I'm considering purchasing an external DAC, as the built-in DAC in the Yamaha a-s501 amplifier leaves much to be desired. Furthermore, the audio output from my laptop via HDMI to the TV and then via optical cable to the amplifier is not the best setup, preventing me from unlocking the full potential of my Triangle Comete speakers and Polk Signature Elite ES 10 subwoofer. Therefore, in hopes of improving sound quality, I'd like to install a good DAC between my laptop and amplifier, allowing me to output video from my laptop via HDMI to the TV and audio from the DAC to the amplifier. The laptop has a USB-C port. I'm not interested in streaming, as I have a large collection of high-resolution music on external drives. Any comments on this matter would be appreciated.
Welcome to ASR!
Please repost in English or thread will be deleted.
Thanks!
Since I was curious:
"Hello everyone! I have a question about purchasing an external DAC, as the built-in DAC of my Yamaha A-S501 amplifier leaves much to be desired. Furthermore, outputting sound from my laptop via HDMI through the TV, and then via optical cable to the amplifier, is not the best setup and doesn't allow me to fully utilize the potential of my Triangle Comete speakers and Polk Signature Elite ES 10 subwoofer. Therefore, hoping for an improvement in sound quality, I want to insert a good DAC between the laptop and the amplifier, while still outputting video from the laptop via HDMI to the TV, and audio through the DAC to the amplifier. My laptop has a USB-C output. Streaming is not of interest to me, as I have a large collection of high-resolution audio files on external drives. I would appreciate any comments on this matter."
To which I'd say the dac in the AS501 is not likely the problem.
Добро пожаловать в ASR!
Пожалуйста, переформулируйте сообщение на английском языке, иначе тема будет удалена.
Спасибо!
Как это сделать на английском, я не знаю
Поскольку мне было любопытно:
«Здравствуйте! У меня вопрос о покупке внешнего ЦАП, так как встроенный ЦАП моего усилителя Yamaha A-S501 оставляет желать лучшего. Кроме того, вывод звука с ноутбука через HDMI на телевизор, а затем через оптический кабель на усилитель, — не самая оптимальная схема, которая не позволяет мне в полной мере использовать потенциал моих колонок Triangle Comete и сабвуфера Polk Signature Elite ES 10. Поэтому, надеясь на улучшение качества звука, я хочу установить хороший ЦАП между ноутбуком и усилителем, при этом продолжая выводить видео с ноутбука через HDMI на телевизор и аудио через ЦАП на усилитель. Мой ноутбук имеет выход USB-C. Стриминг меня не интересует, так как у меня большая коллекция аудиофайлов высокого разрешения на внешних накопителях. Буду благодарен за любые комментарии по этому поводу.»
На это я бы ответил, что проблема, скорее всего, не в ЦАП в AS501.
Я подумывал об этом, что может лучше не заморачиваться с ЦАПом, а смотреть в сторону хорошего усилителя... Может подкинете пару вариантов на этот счёт
You should use google translate or similar. In any case, the amp isn't likely your problem either. You don't actually describe any problem other than you imagine it might somehow be different if you arbitrarily change gear.
Вам следует воспользоваться Google Translate или аналогичным сервисом. В любом случае, усилитель, скорее всего, тоже не является вашей проблемой. Вы, по сути, не описываете никакой проблемы, кроме того, что, как вы предполагаете, ситуация может как-то измениться, если вы произвольно смените оборудование.
Я надеялся улучшить качество звука, добавив хороший ЦАП или что-то подобное. Как я могу улучшить свою систему в целом, чтобы заметить разницу в лучшую сторону?
err ?
err ?
he still refuses to speak/type english
Folks, please be patient as he has managed to fix the OP and thread title.
How do you know it’s the DAC that is the problem?
Maybe. Some TVs have poor SPDIF outputs. What TV make and model is it?
Lots of DACs were tested at ASR. There is something in any price bracket. Just check the review index:
If the TV is the issue, a simple USB to toslink converter would also work fine SMSL has a few: PO100 (pro).
But really, better sound starts with better speakers. Amps and DACs are way down on the list.
I'd also start with speakers, perhaps your placement/room as well before suspecting the electronics....
Thank you for your patience! I'm really trying. I typed the text into the translator, translated it into English, copied it, pasted it, but here it automatically translated back into Russian. I don't know why that happens. Let's see how it goes this time.
To be honest, I don't know if the problem lies with the DAC or if there is a problem at all. Basically, there is sound, and it's not bad. But given that the DAC in the amplifier is very mediocre, I assumed that connecting a more advanced DAC would bring a noticeable improvement in sound. As for the TV, I think the optical output is quite suitable. It's a 2023 LG Qned 816 model.
Check out this topic:
Я бы также начал с проверки колонок, возможно, с оценки расположения/комнаты, прежде чем подозревать
Very unlikely the problem lies with the dac unless it is simply broken. The dac in the amp is perfectly adequate, advanced dac might have better numbers, but not likely any audible differences. Sourcing sound from a tv, meh.
Конечно, я не утверждаю, что это акустические системы премиум-класса, но, как я уже писал, они не самые худшие, Triangle Esprit Ez Comete, и я считаю, что встроенный ЦАП усилителя не способен в полной мере раскрыть их потенциал. Возможно, с внешним ЦАП усилитель сможет лучше выдавать свои 80 Вт на канал, поскольку ему не придётся питать собственный ЦАП. Что ж, это всего лишь предположение. Как вы, возможно, догадались, я новичок в мире Hi-Fi, но очень увлечён им.
In english?
Of course, I don't claim that these are premium speakers, but as I already wrote, they are not the worst, namely Triangle Esprit Ez Comete, and I believe that the amplifier's native DAC is not capable of fully revealing their potential. And perhaps with an external DAC installed, the amplifier will be able to better deliver its 80 watts per channel, as it will not be powering its own DAC. Well, that's just a guess. As you may have guessed, I am new to the world of Hi-Fi, but very enthusiastic.
