Connect my PC via HDMI to AVR (Marantz), what do I set Windows sound settings to?
flexy123
For a 5.1 setup and a HTPC for movies, using MPC-HC.
The AVR is connected via HDMI. Yes I see bitstreaming formats in Windows in "sound card" settings for the Marantz.
Is it correct that I need the *Windows* sound settings on Stereo for the AVR (do I need to set Full Range speakers??) so it does BitStreaming? Because I believe I read somewhere when it is set to 5.1 in Windows, then Windows does the encoding, and of course it shouldn't since I have an AVR (SR5013) for that...
Likewise, I assume that MPC-HC will have some options for this as well, just didnt have time to look into this.
Strangely enough, I haven't seen this (Windows sound settings when connecting an AVR) discussed much...but to me it seems important as "common sense" would tell one to set to 5.1 also in Windows...
Thanks!
Using Bitstream should bypass all Windows sound settings, just as using ASIO or Wasapi Shared does.
